[OpenLayers-Dev] [vector-behavior] strategies and inRange
Eric Lemoine eric.c2c at gmail.com
Fri Jul 18 12:29:43 EDT 2008
Yes, by registering a moveend listener on its layer the strategy will
only receive moveend events if the layer moveTo was called, i.e. if
the layer is visible and in range. This is making sense to me. What do
you guys think? Eric
2008/7/18, Pierre GIRAUD <bluecarto at gmail.com>:
> Hi all,
> I'm playing with the code in the vector-behavior sandbox.
> I found that the strategies (at least BBOX and Grid) don't check if
> the layer is in range.
> We can add code as following to support that :
> Index: lib/OpenLayers/Strategy/Grid.js
> --- lib/OpenLayers/Strategy/Grid.js     (revision 7544)
> +++ lib/OpenLayers/Strategy/Grid.js     (working copy)
>  -276,7 +276,9 @@
>      refresh: function(evt) {
>          var bounds = this.layer.map.getExtent();
>          var force = evt.zoomChanged || evt.force;
> -        this.grid.moveTo(bounds, force);
> +        if (this.layer.inRange && this.layer.visibility) {
> +            this.grid.moveTo(bounds, force);
>      CLASS_NAME: "OpenLayers.Strategy.Grid"
> But, it feels like we duplicate some code as the inRange and
> visibility checks are already made at the map level.
> Instead we could imagine adding a "moveend" event at the layer level.
> It would be triggered only when the layer is moved itself. And the
> strategies would register to this new event.
> Tshaub and sbenthall, please tell me if you feel confident with this.
> If so, I can commit something very quickly in the sandbox.
> Regards,
> Pierre
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev mailing list
