[OpenLayers-Dev] svn 1.5
Eric Lemoine
eric.c2c at gmail.com
Tue Jul 29 00:55:06 EDT 2008
Hi Tim. So long that users need not upgrade their SVN clients, i see
no problem with having the repository going to 1.5. Talking about that
have people give SVK a try? SVK can check out code from SVN
repositories, and, IIRC, supports the same "merge without out
indicating the previous merge revision" feature. Eric
2008/7/29, Tim Schaub <tschaub at opengeo.org>:
> Hey-
> Wondering if others think a move to subversion 1.5 would be good.
> A few features would be nice for OL development. Particularly merge
> tracking. From the release notes:
> Merging changes from (say) trunk to a branch no longer requires that you
> specify the revision range. Instead, each time you want to sync up with
> trunk, you can just do:
> $ cd BRANCH_WORKING_COPY
> $ svn merge URL_TO_TRUNK
> Subversion will figure out what changes from URL_TO_TRUNK have not yet
> been merged and pull in just those changes. When it's time to merge the
> branch back to trunk, do this:
> $ cd TRUNK_WORKING_COPY
> $ svn merge --reintegrate URL_TO_BRANCH
> http://subversion.tigris.org/svn_1.5_releasenotes.html#merge-tracking
> Pretty nice for sandbox users. Not sure if there are constraints on
> doing this on the MC side.
> Tim
> PS - One (perhaps very minor) change that may affect some is that the
> repository basename is displayed in XML and HTML index views. This
> breaks anything that previously relied on titles that were only revision
> numbers (zc.buildout recipes break).
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev
