[OpenLayers-Dev] Examples behave different in IE due to Quirks
Mode
Andreas Hocevar
andreas.hocevar at gmail.com
Wed Jun 11 16:20:54 EDT 2008
Hey Chris,
On Wed, Jun 11, 2008 at 1:08 PM, Christopher Schmidt
<crschmidt at metacarta.com> wrote:
> On Wed, Jun 11, 2008 at 11:05:01AM +0200, Andreas Hocevar wrote:
>> Should we change the examples to use standards compliant mode?
> In general, I haven't tested OpenLayers in anything other than quirks
> mode, so I'm not sure that all things -- like vector rendering and the
> like -- work correctly. If they do, then I'm fine with that.
Ok, I can test everything piece by piece. Might take some time though.
The only issue with standards-compliant mode I encountered so far is
that map cursors are incorrect, but that might be related to Ext JS,
which is also involved in that application. I have not investigated
that further so far.
Regards,
Andreas.
More information about the Dev
