[OpenLayers-Dev] Examples behave different in IE due to Quirks
Mode
Eric Lemoine
eric.c2c at gmail.com
Thu Jun 12 02:28:50 EDT 2008
I very often use the vector layers and controls in non-quirks mode and
i've had on problem so far. I dont know about the framed popup, worth
a try. Cheers, Eric
2008/6/11, Christopher Schmidt <crschmidt at metacarta.com>:
> On Wed, Jun 11, 2008 at 10:20:54PM +0200, Andreas Hocevar wrote:
>> Hey Chris,
>> On Wed, Jun 11, 2008 at 1:08 PM, Christopher Schmidt
>> <crschmidt at metacarta.com> wrote:
>> > On Wed, Jun 11, 2008 at 11:05:01AM +0200, Andreas Hocevar wrote:
>> >> Should we change the examples to use standards compliant mode?
>> > In general, I haven't tested OpenLayers in anything other than quirks
>> > mode, so I'm not sure that all things -- like vector rendering and the
>> > like -- work correctly. If they do, then I'm fine with that.
>> Ok, I can test everything piece by piece. Might take some time though.
>> The only issue with standards-compliant mode I encountered so far is
>> that map cursors are incorrect, but that might be related to Ext JS,
>> which is also involved in that application. I have not investigated
>> that further so far.
> I'm not that concerned: if we should change it, I'm happy to do so; I
> just know that I'd seen a couple of reports of it being funky in
> non-quirks mode. If draw-feature and sundials work, then I'm fine -- no
> need to bend over backwards, imho.
> Regards,
> Christopher Schmidt
> MetaCarta
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev
