[OpenLayers-Dev] [OpenLayers-Trac] [OpenLayers] #1483:
ModifyFeature control makes SelectFeature control to modify features
Dipl. Inf. Carsten Eider
eider at fh-bingen.de
Mon Jun 16 08:15:35 EDT 2008
Has anyone developed a solution or found a workaround?
OpenLayers schrieb:
> #1483: ModifyFeature control makes SelectFeature control to modify features
> Reporter: openlayers | Owner: tschaub
> Type: bug | Status: new
> Priority: minor | Milestone:
> Component: Control.ModifyFeature | Version: 2.6 RC1
> Keywords: | State:
> If I add ModifyFeature and SelectFeature controls to a map and connect
> them to the same layers, selection too becomes modification tool. When I
> select a feature with SelectFeature control I can see and change
> modification points(vertex) around the feature. The problem seems to be on
> ModifyFeature control. It connect events to the layer when it is
> initialized instead of when it is activated. Should those events be
> connected and disconnect on activate and deactivate operations instead? I
> attached a file that demonstrates this bug, it is modified from modify-
> feature.html example. Create polygon and click "select" radiobutton and
> select created polygon from map.
Mit freundlichen Grüßen / Yours faithfully
Carsten Eider
Dipl. Inf. (FH)
Kompetenzzentrum für Innovative Informationssysteme
c/o Fachhochschhule Bingen / University of applied sciences Bingen
Berlinstraße 109
55411 Bingen
Tel: +49 (0) 6721 / 409-179
Fax: +49 (0) 6721 / 409-158
email: eider at fh-bingen.de
Internet: iis.fh-bingen.de
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20080616/817a906c/eider.vcf
More information about the Dev
