[OpenLayers-Dev] use a layer's maxextent to determine visibility
Christopher Schmidt crschmidt at metacarta.com
Thu Jun 19 08:34:43 EDT 2008
On Thu, Jun 19, 2008 at 11:30:06AM +0200, John Pulles wrote:
> Hi list,
> I'm working on a site where many wms providers are used, covering only a
> relatively small area of the country. Since the maxextent of their layers is
> known, I would like this maxextent to be used when OpenLayers calculates the
> visibility of the layer, thus preventing many getmap requests for empty
> layer images.
Tiles outside maxExtent aren't (or at least, 'shouldn't be') requested,
even if the layer is turned on. calculateInRange is designed to solve
the problem of scale ranges, *not* extent ranges, and changing this
function seems likely to cause problems -- it is assumed throughout the
code that this is designed to change on zoom, thogh I can't say for
*sure* that it wouldn't work otherwise.
Instead, I think we should figure out why tiles that don't overlap with
your WMS maxExtent are being requested. They shouldn't be.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
