[OpenLayers-Dev] (no subject)
Xavid xavid at MIT.EDU
Tue Jun 24 20:13:16 EDT 2008
On 2008/06/24, at 19:20, Darko Radiceski wrote:
> Any particular setting that i am after?
One thing to check would be to make sure you can load all the
Javascript files your page is using (OpenLayers.js, etc.) manually in
your web browser.  Other than that, I'm not sure.
~Xavid
> On 6/25/08, Xavid <xavid at mit.edu> wrote:
> On 2008/06/24, at 19:05, Darko Radiceski wrote:
> That is why i am surprised why it gives me that error....I have
> tried on few other server that dont have both IIS and Apache
> installed and that error is not present there. So i assume it has to
> do somethign with confusion between the two.
> OpenLayers is only run in the browser, so it doesn't care what
> server you're running.  Having your servers misconfigured could
> break OpenLayers by, say, not serving all the files your OpenLayers-
> using page refers to, but any webserver or combination of servers
> should work with normal configurations.  You might want to check
> your server configuration (or maybe permissions) on the troublesome
> server.
> ~Xavid
> On 6/25/08, Christian López Espínola <penyaskito at gmail.com> wrote:
> It's only javascript. There shouldn't be a problem at all.
> On Wed, Jun 25, 2008 at 12:07 AM, Darko Radiceski
> <radiceski at gmail.com> wrote:
> > greeting all,
> > does open layers have problems when deploying on a system that has
> > both apache and iis?
> > I have that case.I installed my open layers site on iis and also
> > apache and it fails....I then changed the port of iis to 81 and
> when I
> > tried to deploy on iis it worked.
> > anything special I have to do if I do this through apache?apache
> is on
> > the windows box that has iis too.
> > cheers
> > dan
> > Radiceski Dan
> > University of Wollongong
> > Australia
> > SIFE - UOW Chapter - Alumni
> > CASUAL ACADEMIC STAFF TEACHING - UOW SITACS
> > (School of Information Technology and Computer Science,University
> of Wollongong)
> > Univeristy of Wollongong - Alumni
> > Dev mailing list
> > Dev at openlayers.org
> > http://openlayers.org/mailman/listinfo/dev
> Cheers,
> Christian López Espínola <penyaskito>
> Radiceski Darko
> Australia
> (School of Information Technology and Computer Science,University of
> Wollongong)
> Dev mailing list
> Radiceski Darko
> Australia
> Wollongong)
More information about the Dev mailing list
