[OpenLayers-Dev] scale depended WMS layers
Eric Lemoine eric.c2c at gmail.com
Wed Jun 25 10:36:05 EDT 2008
2008/6/25 Darko Radiceski <radiceski at gmail.com>:
> Greetings all,
> Does OpenLayers have the support for scale depended layers?
> I need to talk to ARC IMS which aparently handles the layer visibility
> dependent on scale. The layers that dependend on the scale are up to 24....
> Do i need to td anything on the OpenLayers side to cator for this scale
> dependend viewing? Any setup or any parameters that need to be past?
> I assume how it would work is:
> Depending on the bounding box ARC IMS can work out the scale and then return
> only one visible and 23 transparent layers......Any accuracy in that?
Yes, this scale-based layer visibility thing is all dealt with by your
map server, no need for OpenLayers support here. Unless I'm missing
your point...
Eric
More information about the Dev mailing list
