[OpenLayers-Dev] making open layers work offline
Erik Uzureau
euzuro at gmail.com
Thu Jun 26 23:11:53 EDT 2008
If you dont need to zoom and pan around a bunch, an even easier
solution would be to just load an OpenLayers.Layer.Image
On Thu, Jun 26, 2008 at 3:40 AM, Ivan Grcic <ivan.grcic at geofoto.hr> wrote:
> Hi Darko,
> pretty easy solution would also be to just install Geoserver and just
> fill it with tiffs, throught coveragestores, and geoserver will serve
> them trought WMS services....nice turorial can be found at:
> http://geoserver.org/display/GEOSDOC/User+Tutorial+Coverage
> regards, Ivan
> On Wed, Jun 25, 2008 at 4:14 PM, Eric Lemoine <eric.c2c at gmail.com> wrote:
>> 2008/6/25 Darko Radiceski <radiceski at gmail.com>:
>>> Dear all,
>>> Just a question:
>>> Some demos i do i cant relly on an internet connection to hook up to my wms
>>> services.
>>> What i would like to do is possibly have a publishing server running
>>> locally. Would it be possible to display something like a geotiff in open
>>> layers?
>> You need some map server to read GeoTiff images and convert them to
>> something that browsers can display. Thus, the easiest might be to
>> install locally a map server with your WMS services. There are other
>> options but this one is pretty simple to set up I think.
>> Eric
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
> Dev mailing list
More information about the Dev
