[OpenLayers-Dev] making open layers work offline
Ivan Grcic
ivan.grcic at geofoto.hr
Fri Jun 27 14:48:50 EDT 2008
Yep, thats also an option, possibly faster option then geoserver
alone, allthough it maybe require little bit tunning with openlayers
the gserver... I would recomend tilecache in mod_python + geoserver...
http://geoserver.org/display/GEOSDOC/TileCache+Tutorial
http://oegeo.wordpress.com/2008/03/17/benchmarking-tilecache-part-1/
http://oegeo.wordpress.com/2008/03/10/tilecache-on-windows-part-2-mod_python/
cheers
On Fri, Jun 27, 2008 at 6:29 PM, Tim Schaub <tschaub at opengeo.org> wrote:
> Hey-
> Another solution I use quite often is to pre-cache with TileCache and
> then use a TileCache layer.
> This doesn't even require Apache running if your cache can be accessed
> with a relative path (from your html page).
> Tim
> Erik Uzureau wrote:
>> If you dont need to zoom and pan around a bunch, an even easier
>> solution would be to just load an OpenLayers.Layer.Image
>> On Thu, Jun 26, 2008 at 3:40 AM, Ivan Grcic <ivan.grcic at geofoto.hr> wrote:
>>> Hi Darko,
>>> pretty easy solution would also be to just install Geoserver and just
>>> fill it with tiffs, throught coveragestores, and geoserver will serve
>>> them trought WMS services....nice turorial can be found at:
>>> http://geoserver.org/display/GEOSDOC/User+Tutorial+Coverage
>>> regards, Ivan
>>> On Wed, Jun 25, 2008 at 4:14 PM, Eric Lemoine <eric.c2c at gmail.com> wrote:
>>>> 2008/6/25 Darko Radiceski <radiceski at gmail.com>:
>>>>> Dear all,
>>>>> Just a question:
>>>>> Some demos i do i cant relly on an internet connection to hook up to my wms
>>>>> services.
>>>>> What i would like to do is possibly have a publishing server running
>>>>> locally. Would it be possible to display something like a geotiff in open
>>>>> layers?
>>>> You need some map server to read GeoTiff images and convert them to
>>>> something that browsers can display. Thus, the easiest might be to
>>>> install locally a map server with your WMS services. There are other
>>>> options but this one is pretty simple to set up I think.
>>>> Eric
>>>> _______________________________________________
>>>> Dev mailing list
>>>> Dev at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/dev
>>> Dev mailing list
>> Dev mailing list
>> !DSPAM:4033,48645a7c140405210051143!
> Dev mailing list
Ivan Grcic
igrcic at gmail.com
Mobile (CRO): +385 98 576 457
More information about the Dev
