[OpenLayers-Dev] Open Layers Documentation
Nader Chouman - WSN
naderc at wsn.net
Mon Mar 3 11:22:39 EST 2008
Hi list,
I am a software developer with a solution integrating company called "Wall Street Networks" and I recently started working with OL as I found it can be very useful in terms of some projects we are currently working on. However, I couldn't get much out of the documentation provided by the site. I would appreciate some references to related resources and to a well defined Programmers API with explanation or examples of the parameters, properties and methods exposed by different classes in OL. I appreciate any help I can get.
Thank you,
[http://www.wsn.net/images/spacer.gif]
[http://www.wsn.net/Images/dsPlaceHolder.gif]
NADER CHOUMAN
Software Developer
110 Wall Street, 15th Floor
New York, NY 10005
Tel 212.635.0100 x245
Fax 212.635.0030
naderc at wsn.net<mailto:naderc at wsn.net>
www.wsn.net
[http://www.wsn.net/Images/dsLogo.gif]<http://www.wsn.net/default.aspx>
The information transmitted is intended only for the person or entity to which it is addressed and may contain confidential and/or privileged material. Any review, retransmission, dissemination or other use of, or taking of any action in reliance upon, this information by persons or entities other than the intended recipient is prohibited. If you received this in error, please contact the sender and delete the material from all computers. Thank You.
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20080303/cb1ef09b/attachment.html
More information about the Dev
