[OpenLayers-Dev] svn build problems
Stephen Woodbridge woodbri at swoodbridge.com
Mon Mar 3 19:23:41 EST 2008
Christopher Schmidt wrote:
> On Mon, Mar 03, 2008 at 04:18:39PM -0500, Stephen Woodbridge wrote:
>> Hi all,
>> I have been getting the following issue in svn trying to run ./build.py
>> full.cfg
>> woodbri at carto:~/work/openlayers/ol-svn/trunk/openlayers/build$
>> ./build.py full.cfg
>> Merging libraries.
>> [snip lots of files]
>> Resolution pass 1...
>> Importing: OpenLayers/Format/XML.js
>> Traceback (most recent call last):
>>    File "./build.py", line 34, in ?
>>      merged = mergejs.run(sourceDirectory, None, configFilename)
>>    File "../tools/mergejs.py", line 190, in run
>>      content = open(fullpath, "U").read() # TODO: Ensure end of line @ EOF?
>> IOError: [Errno 2] No such file or directory:
>> '../lib/OpenLayers/Format/XML.js'
>> Does this indicate something needs to be fixed, maybe the user :) in
>> this case.
> That seems a rather unusual situation: the default build, for me,
> doesn't have any "Importing" after "Resolution pass 1". Perhaps you have
> some extra code?
> Anyway, it also seems that you don't have an OpenLayers/Format/XML.js
> file. There is definitely one of those in trunk, so you're in trouble
> here. Try checking out a clean working copy? Perhaps yours got hosed.
> 'svn status' might help figure out how/why.
ok, I just nuked it and checked out a new version, all is good and the
build works fine now. Sorry, I have no idea what that was all about, but
something was obviously whacked. Thank you for the suggestions.
-Steve W
More information about the Dev mailing list
