[OpenLayers-Dev] svn build problems
XinGang Li slinavlee at gmail.com
Wed Mar 5 01:13:20 EST 2008
> Christopher Schmidt wrote:
> > On Mon, Mar 03, 2008 at 04:18:39PM -0500, Stephen Woodbridge wrote:
> >> Hi all,
> >> I have been getting the following issue in svn trying to run ./build.py
> >> full.cfg
> >> woodbri at carto:~/work/openlayers/ol-svn/trunk/openlayers/build$
> >> ./build.py full.cfg
> >> Merging libraries.
> >> [snip lots of files]
> >> Resolution pass 1...
> >> Importing: OpenLayers/Format/XML.js
> >> Traceback (most recent call last):
> >>    File "./build.py", line 34, in ?
> >>      merged = mergejs.run(sourceDirectory, None, configFilename)
> >>    File "../tools/mergejs.py", line 190, in run
> >>      content = open(fullpath, "U").read() # TODO: Ensure end of line @
> EOF?
> >> IOError: [Errno 2] No such file or directory:
> >> '../lib/OpenLayers/Format/XML.js'
> >> Does this indicate something needs to be fixed, maybe the user :) in
> >> this case.
> > That seems a rather unusual situation: the default build, for me,
> > doesn't have any "Importing" after "Resolution pass 1". Perhaps you have
> > some extra code?
> > Anyway, it also seems that you don't have an OpenLayers/Format/XML.js
> > file. There is definitely one of those in trunk, so you're in trouble
> > here. Try checking out a clean working copy? Perhaps yours got hosed.
> > 'svn status' might help figure out how/why.
> ok, I just nuked it and checked out a new version, all is good and the
> build works fine now. Sorry, I have no idea what that was all about, but
> something was obviously whacked. Thank you for the suggestions.
> -Steve W
May be you need to install python 2.5
Li XinGang
EMail: slinavlee at gmail.com
Blog:   avlee.cnblogs.com
Site:    www.mapboost.org.cn
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20080305/2f1d4698/attachment.html
More information about the Dev mailing list
