Hy guys, do you know if Xlink is compatible with IE7 in order to use the xlink:href tags? Thanks for your help! Fabrice GIS developper -- View this message in context: http://www.nabble.com/Xlink-sous-IE-tp15853289p15853289.html Sent from the OpenLayers Dev mailing list archive at Nabble.com.
