[OpenLayers-Dev] Xlink sous IE
Pierre GIRAUD
bluecarto at gmail.com
Thu Mar 6 04:33:02 EST 2008
On Thu, Mar 6, 2008 at 10:29 AM, Andreas Hocevar
<andreas.hocevar at gmail.com> wrote:
> Fabrice,
> Pierre GIRAUD wrote:
> > What do you mean by "I'm using an SVG image" ? Where is the SVG image
> > added to your code ?
> Do you want to use the SVG image to symbolize point features? If that is
> the case, you could just use the externalGraphic symbolizer property. As
> long as you use gif or png images, this will work in IE and Firefox. If
> you use SVG vector images, it will not work on IE.
Unless you use something like what I started to work on some time ago.
See http://dev.openlayers.org/sandbox/camptocamp/vectorSymbols/examples/vector-symbols.html
Regards,
Pierre
More information about the Dev
