[OpenLayers-Dev] Re : OpenLayers.loadURL( ) : params - Params on
get (doesnt seem to work)
Jc Albert
jcalbert802 at yahoo.fr
Fri Mar 7 03:40:18 EST 2008
A suggestion :
In Util.js at line ~825
In the function "OpenLayers.Util.getParameters (url)"
You have :
//parse out parameters portion of url string
var paramsString = "";
I propose :
var paramsString = url;
I tested it, and that solved the problem here...
Regards
Jean-Christophe
----- Message d'origine ----
De : Eric Lemoine <eric.c2c at gmail.com>
À : Jc Albert <jcalbert802 at yahoo.fr>
Cc : dev at openlayers.org
Envoyé le : Jeudi, 6 Mars 2008, 21h41mn 51s
Objet : Re: [OpenLayers-Dev] OpenLayers.loadURL( ) : params - Params on get (doesnt seem to work)
On Thu, Mar 6, 2008 at 9:36 PM, Eric Lemoine <eric.c2c at gmail.com> wrote:
> 2008/3/6 Jc Albert <jcalbert802 at yahoo.fr>:
> > Hi,
> > When calling this function the 'params' parameter doesn't work.
> > I think I've found why :
> > When you call OpenLayers.loadURL(url, param,... ) and you give string like
> > param = "toto=blabla&titi=haha";
> > The following function (Ajax.js, line 257) :
> > this.options.parameters =
> > OpenLayers.Util.getParameters(this.options.parameters);
> > return null.
> > OpenLayers.Util.getParameters() seems to need a full url like
> > "page.php?toto=blabla&titi=haha" to work.
> > if you only give the params, it return null. So parameters are lost.
> Hi Jc
> It looks like you've found a bug in the Ajax code. Note however that
> providing a object instead of a string should work:
> OpenLayers.loadURL(url, {'fookey':'fooval','barkey':'barval'});
I've opened a ticket for this stuff: <http://trac.openlayers.org/ticket/1419>
Thanks for reporting this Jc.
Eric
_____________________________________________________________________________
Envoyez avec Yahoo! Mail. Une boite mail plus intelligente http://mail.yahoo.fr
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20080307/e90c3ddf/attachment.html
More information about the Dev
