[OpenLayers-Dev] Google base layer not showing, when switching base layers
Bart van den Eijnden (OSGIS) bartvde at osgis.nl
Fri Mar 21 07:51:15 EDT 2008
It seems the Google layer has a minResolution of null, this goes as well
for maxResolution. That's why the fix for #1429 breaks this.
Someone already opened:
http://trac.openlayers.org/ticket/1457
which should be used for further discussion I guess.
Best regards,
Bart
Hans Bogaards wrote:
> Hi All,
> While running the trunk version, our map stopped working.
> We have 2 base layers, one made up of GeoTIFFs, the other Google maps.
> The GeoTIFF layer is cached using TileCache. When we switch base
> layers, the Google layer stays white.
> I have traced the reason why it stopped working to a patch for issue
> #1429 (Changeset 6540). When I undo this change, changing the base
> layers works again.
> I'll attach a small demo of the problem
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
More information about the Dev mailing list
