[OpenLayers-Dev] rules and filters. i'm confused
Dejung Gewissler
dejung.gewissler at oit.state.nj.us
Tue May 20 11:37:31 EDT 2008
Thanks Eric. I've changed my OpenLayers.Rule.Comparison to
OpenLayers.Filter.Comparison and the data loads ok. The problem I face
now is that all the features are rendered with the else filter and the
comparison filters aren't honored.
var GeoJSON_style = new OpenLayers.Style();
var rulePopGreat = new OpenLayers.Filter.Comparison(
type: OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO,
property: "POP2000",
value: 500000,
symbolizer: {
Polygon: {fillColor: "#FFFF00", strokeColor: "gray"}
var elseRule = new OpenLayers.Filter(
{elseFilter: true,
symbolizer: {Polygon: {fillColor: "#FFFFFF", strokeColor:
"gray"}}
GeoJSON_style.addRules([rulePopGreat, elseRule]);
var GeoJSON = new OpenLayers.Layer.GML("GeoJSON Vectors",
"County_JSON_Simplified.json",
{visibility:false, maxResolution:5000, minResolution:1, format:
OpenLayers.Format.GeoJSON,
styleMap: new OpenLayers.StyleMap({
"default": GeoJSON_style})
Thanks,
Dejung
Eric Lemoine wrote:
> With 2.6 and trunk you should indeed OpenLayers.Filter.Comparison.
> Eric
More information about the Dev
