[OpenLayers-Dev] rules and filters. i'm confused
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Tue May 20 12:17:24 EDT 2008
I think you need to do something like:
var rulePopGreat = new OpenLayers.Rule(
filter: new OpenLayers.Filter.Comparison({
type: OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO,
property: "POP2000",
value: 500000 }),
symbolizer: {
Polygon: {fillColor: "#FFFF00", strokeColor: "gray"}
Best regards,
Bart
Eric Lemoine wrote:
> Hi. I think you must add your filters to a rule object then add the
> rule to the style object. Can't really check right now, am on a cell
> phone. Cheers
> 2008/5/20, Dejung Gewissler <dejung.gewissler at oit.state.nj.us>:
>> Thanks Eric. I've changed my OpenLayers.Rule.Comparison to
>> OpenLayers.Filter.Comparison and the data loads ok. The problem I face
>> now is that all the features are rendered with the else filter and the
>> comparison filters aren't honored.
>> var GeoJSON_style = new OpenLayers.Style();
>> var rulePopGreat = new OpenLayers.Filter.Comparison(
>> value: 500000,
>> symbolizer: {
>> var elseRule = new OpenLayers.Filter(
>> {elseFilter: true,
>> symbolizer: {Polygon: {fillColor: "#FFFFFF", strokeColor:
>> "gray"}}
>> GeoJSON_style.addRules([rulePopGreat, elseRule]);
>> var GeoJSON = new OpenLayers.Layer.GML("GeoJSON Vectors",
>> "County_JSON_Simplified.json",
>> {visibility:false, maxResolution:5000, minResolution:1, format:
>> OpenLayers.Format.GeoJSON,
>> styleMap: new OpenLayers.StyleMap({
>> "default": GeoJSON_style})
>> Thanks,
>> Dejung
>> Eric Lemoine wrote:
>>> With 2.6 and trunk you should indeed OpenLayers.Filter.Comparison.
>>> Eric
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
More information about the Dev
