[OpenLayers-Dev] Bug in rendering features with cluster strategy
Tim Schaub
tschaub at opengeo.org
Mon Nov 3 23:45:35 EST 2008
Hey-
Ivan Grcic wrote:
> OK... i found it..inside Layer.Vector...now the question is: should i
> put something like this:
> if (OpenLayers.Util.indexOf(this.features, feature) != -1){
> inside drawFeature: function(feature, style) {
Nope. Making drawFeature that safe at the expense of iterating through
every feature with every draw is a mistake.
> or inside every other function inside Layer.Vector that uses
> drawFeature function?
> When I put it here:
> --> if (OpenLayers.Util.indexOf(this.features, feature) != -1){
> it works pretty fine for me :) Eric?
> On Mon, Nov 3, 2008 at 9:53 AM, Ivan Grcic <ivan.grcic at geofoto.hr> wrote:
>> Yup, its not Cluster Strategy...
>> http://trac.openlayers.org/ticket/1806#comment:2
>> On Mon, Nov 3, 2008 at 9:11 AM, Eric Lemoine <eric.c2c at gmail.com> wrote:
>>> Hi.
>>> Yes, this looks like a bug in OpenLayers.
>>> I'm under the impression that this isn't a bug in the cluster strategy
>>> but either in Layer.Vector or in Control.SelectFeature. Indeed, I
>>> think SelectFeature calls layer.drawFeature on feature
>>> selection/unselection without checking whether the feature is in the
>>> layer. And i'm saying this may be a bug in Layer.Vector because it may
>>> be that drawFeature should be responsible for checking whether the
>>> feature is in the layer before actually drawing it.
>>> This is just coming from the top of my head so i may be wrong, but i'm
>>> feeling this is a good track to follow :)
>>> Eric
>>> 2008/11/2, Ivan Grcic <ivan.grcic at geofoto.hr>:
>>>> Hi list,
>>>> i discovered a bug while developing my OL application, in cluster
>>>> strategy class.
>>>> Bug occurs when you hover over one feature that represent a cluster
>>>> (or externalGraphic or like in cluster example - vector circle
>>>> http://openlayers.org/dev/examples/strategy-cluster.html)
>>>> When you zoom in/out while that feature-cluster is selected (by
>>>> quickly double-clicking or easier using scroll on ur mouse), on next
>>>> zoom that cluster is rendered (stays on screen) together with newly
>>>> created clusters! And clearly it shouldnt be there. The old
>>>> ("phantom") cluster is not selectable, as he doesnt exist on the new
>>>> zoom level..he just stays there on screen...annoying me :)
>>>> As you zoom in again and again, phantom clusters always render, always
>>>> at the same position in the map div...
>>>> Please confirm that this is a bug, im going crazy here with this one :|
>>>> Ivan Grcic
>>>> _______________________________________________
>>>> Dev mailing list
>>>> Dev at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/dev
>> Ivan Grcic
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev
