[OpenLayers-Dev] SVG Format patch q's
Jonathan Lister jon at osmosoft.com
Tue Nov 4 13:31:32 EST 2008
Hello,
Thanks to crschmidt for rationalising my patches into a single big patch:
http://trac.openlayers.org/ticket/1808
Here is an extract from the ticket notes, with questions and comments inline:
> Notes from a real quick run:
>In FF3, the tests throw a weird 'Ci is not defined' error for me. In Safari, the example doesn't work for me. (I don't know why.)
Thanks for checking this out, I'll look into these.
> Your example includes a reference to the Virtual Earth JS which seems unneccesary; I'd recommend just removing it.
Agreed.
> The format doesn't yet support internalProjection/externalProjection parameters: I'd recommend doing so.
> (if this is too difficult, I can help make it happen.)
I have a couple of questions about this, which expose my lack of
understanding of projections! In short, I really don't know how
setting projection parameters controls the appearance of a map or a
layer, nor how one should support this when reading in data. What is a
projection? How do you convert between them?
Thanks!
J.
http://www.jaybyjayfresh.com
More information about the Dev mailing list
