[OpenLayers-Dev] Bug in rendering features with cluster strategy
    Ivan Grcic
    ivan.grcic at geofoto.hr
    Wed Nov  5 06:30:37 EST 2008
made a new post on on 1782, cuz its probably same issue:
http://trac.openlayers.org/ticket/1782#comment:4
You can remove/add SelectFeature on checkbox.
Regards,
Ivan
On Tue, Nov 4, 2008 at 5:43 PM, Andreas Hocevar <ahocevar at opengeo.org> wrote:
> Hi,
> to me it seems this issue is at least related to
> http://trac.openlayers.org/ticket/1782, probably it is the same issue.
> Ivan, can you please check if the described problem persists when you
> remove the SelectFeature control?
> Thanks,
> Andreas.
> On Tue, Nov 4, 2008 at 5:07 PM, Tim Schaub <tschaub at opengeo.org> wrote:
>> Hey-
>> Ivan Grcic wrote:
>>> Hi guys,
>>> another strange behavior, with similar issue. Features that are not
>>> spuppose to render are rendered!
>>> Im loading my vector feature from gml file, containing 21 features
>>> that are Polygons or MultiPolygons. When you zoom in, lets say on
>>> north part of map, features from south are sometimes also shown, under
>>> corectly rendered features on top...
>>> Im attaching one screenshot, and you can check it out here:
>>> http://dev.openlayers.org/sandbox/igrcic/playground/
>> This is a good example of a valid issue.  However, it doesn't belong on
>> this thread.  I assume you have made a ticket and included a concise
>> description and a link to your example.
>>> Is it becouse of my gml file? I exported it from geoserver , and it
>>> seems pretty ok to me...
>>> On Tue, Nov 4, 2008 at 7:38 AM, Eric Lemoine <eric.c2c at gmail.com> wrote:
>>>> On Tue, Nov 4, 2008 at 6:53 AM, Tim Schaub <tschaub at opengeo.org> wrote:
>>>>> Eric Lemoine wrote:
>>>>>> Tim, what about this case: feature is selected then is *removed* from
>>>>>> the layer.  Eventually the feature handler triggers "mouseout", which
>>>>>> makes the select feature control call drawFeature for a feature which
>>>>>> isn't in the layer. Eric
>>>>> layer.removeFeatures sets feature.layer to null
>>>>> The Feature handler shouldn't handle any features with a non-truthy layer.
>>>> Yeah, I realized that.
>>>> Eric
>>>> _______________________________________________
>>>> Dev mailing list
>>>> Dev at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/dev
>> Tim Schaub
>> OpenGeo - http://opengeo.org
>> Expert service straight from the developers.
>> Dev mailing list
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Dev mailing list
More information about the Dev
