[OpenLayers-Dev] clearing handlers
bartvde at osgis.nl
bartvde at osgis.nl
Thu Nov 6 03:10:20 EST 2008
Hi list,
why is the interface for clearing handlers not standardized? Maybe there
is a good reason for it that I am missing.
For Handler/RegularPolygon.js the function is called clear. It will clear
the renderer of the layer and call destroyFeatures() on the layer.
For Handler/Path.js, Handler/Point.js and Handler/Polygon.js you have to
call destroyFeature directly.
Would it not be better to have a API method called clear on all these
Handlers?
Thoughts?
Best regards,
Bart
More information about the Dev
