[OpenLayers-Dev] Bug in rendering features with cluster strategy
Alexandre Dube
adube at mapgears.com
Fri Nov 7 14:15:35 EST 2008
Answer to my second question... still looking for the first...
>> If not, I would like to disable the wheel zoom. How can I do that ?
oNavCtrl = new OpenLayers.Control.Navigation(
{ 'zoomWheelEnabled': false});
Alexandre Dube wrote:
> I tried this small patch but unfortunately the problem persist. Is there
> a new patch for this issue ( feature stays on screen when zooming with
> mouse over it with cluster strategy ) ?
> Alexandre
> Tim Schaub wrote:
>> Hey-
>> Eric Lemoine wrote:
>>> Yes. Especially since drawFeature is often called from addFeatures,
>>> where we're assured that the feature is in the layer. So, instead, we
>>> may want to change the select feature control so that it calls
>>> drawFeature only if, in the case of selection, the feature is in the
>>> "features" array, and in the case of unselection, the feature is in
>>> the "selectedFeatures" array. What do you think? Eric
>> The problem is in the Feature handler. We destroy features, but
>> references to them are still truthy. Since the destroy code sets the
>> layer property to null, one check of an undestroyed feature is to check
>> feature.layer.
>> See http://trac.openlayers.org/attachment/ticket/1806/destroyed.patch
>>> 2008/11/4, Tim Schaub <tschaub at opengeo.org>:
>>>> Hey-
>>>> Ivan Grcic wrote:
>>>>> OK... i found it..inside Layer.Vector...now the question is: should i
>>>>> put something like this:
>>>>> if (OpenLayers.Util.indexOf(this.features, feature) != -1){
>>>>> inside drawFeature: function(feature, style) {
>>>> Nope. Making drawFeature that safe at the expense of iterating through
>>>> every feature with every draw is a mistake.
>>>>> or inside every other function inside Layer.Vector that uses
>>>>> drawFeature function?
>>>>> When I put it here:
>>>>> --> if (OpenLayers.Util.indexOf(this.features, feature) != -1){
>>>>> it works pretty fine for me :) Eric?
>>>>> On Mon, Nov 3, 2008 at 9:53 AM, Ivan Grcic <ivan.grcic at geofoto.hr> wrote:
>>>>>> Yup, its not Cluster Strategy...
>>>>>> http://trac.openlayers.org/ticket/1806#comment:2
>>>>>> On Mon, Nov 3, 2008 at 9:11 AM, Eric Lemoine <eric.c2c at gmail.com> wrote:
>>>>>>> Hi.
>>>>>>> Yes, this looks like a bug in OpenLayers.
>>>>>>> I'm under the impression that this isn't a bug in the cluster strategy
>>>>>>> but either in Layer.Vector or in Control.SelectFeature. Indeed, I
>>>>>>> think SelectFeature calls layer.drawFeature on feature
>>>>>>> selection/unselection without checking whether the feature is in the
>>>>>>> layer. And i'm saying this may be a bug in Layer.Vector because it may
>>>>>>> be that drawFeature should be responsible for checking whether the
>>>>>>> feature is in the layer before actually drawing it.
>>>>>>> This is just coming from the top of my head so i may be wrong, but i'm
>>>>>>> feeling this is a good track to follow :)
>>>>>>> Eric
>>>>>>> 2008/11/2, Ivan Grcic <ivan.grcic at geofoto.hr>:
>>>>>>>> Hi list,
>>>>>>>> i discovered a bug while developing my OL application, in cluster
>>>>>>>> strategy class.
>>>>>>>> Bug occurs when you hover over one feature that represent a cluster
>>>>>>>> (or externalGraphic or like in cluster example - vector circle
>>>>>>>> http://openlayers.org/dev/examples/strategy-cluster.html)
>>>>>>>> When you zoom in/out while that feature-cluster is selected (by
>>>>>>>> quickly double-clicking or easier using scroll on ur mouse), on next
>>>>>>>> zoom that cluster is rendered (stays on screen) together with newly
>>>>>>>> created clusters! And clearly it shouldnt be there. The old
>>>>>>>> ("phantom") cluster is not selectable, as he doesnt exist on the new
>>>>>>>> zoom level..he just stays there on screen...annoying me :)
>>>>>>>> As you zoom in again and again, phantom clusters always render, always
>>>>>>>> at the same position in the map div...
>>>>>>>> Please confirm that this is a bug, im going crazy here with this one :|
>>>>>>>> Ivan Grcic
>>>>>>>> _______________________________________________
>>>>>>>> Dev mailing list
>>>>>>>> Dev at openlayers.org
>>>>>>>> http://openlayers.org/mailman/listinfo/dev
>>>>>> Ivan Grcic
>>>> Tim Schaub
>>>> OpenGeo - http://opengeo.org
>>>> Expert service straight from the developers.
>>>> Dev mailing list
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Dev
