[OpenLayers-Dev] popup closebox issue
Jerome Freyre
jerome.freyre at hispeed.ch
Mon Nov 10 03:31:37 EST 2008
Hi Eric and euzuro,
I tried the example : http://openlayers.org/dev/examples/popupMatrix.html
On my pc with safari 3.1.2 and the closebox is correctly working and
rendered...
Wich version of safari are you using?
Jerome Freyre wrote:
> Hi Eric,
> There is no problem with the popup closebox on Safari with a mac...
> I'll try this week end on my pc with safari...
> Eric Lemoine-3 wrote:
>> Hello
>> I noticed that the popup closebox is not rendered on Safari (Safari
>> 3.0.3 on Windows). Has anyone else experienced that? Is the problem
>> existing on Safari on Mac as well?
>> Thanks,
>> Eric
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
View this message in context: http://www.nabble.com/popup-closebox-issue-tp20378034p20416102.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
