[OpenLayers-Dev] Cluster strategy getResolution bug ?
Alexandre Dube adube at mapgears.com
Mon Nov 10 14:32:59 EST 2008
Ok thanks Tim,
  I had some trouble at first trying to use
minResolution/maxResolution...  But quickly found out that when you want
a layer only visible at a certain "reach", you must choose either scale
OR resolution to work with, not both.  I was setting maxResolution to
3.527775872778806 but at some point it was given a new value of
35.27775872778806 ( the maxResolution of the baseLayer... ) because I
used scales:[xx,xx,xx].
  Using resolutions[xx,xx,xx] solved this problem.
  But, in the end it didn't help with my cluster strategy problem.  I
still have to hack Cluster.js to make it work properly.  Well, in the
end I don't understand what I'm doing wrong.  Sorry.
Alexandre
Tim Schaub wrote:
> Hey-
> Alexandre Dube wrote:
>> Hi Eric,
>>   Ok, I understand what you mean.  But I already set specific scales to
>> the vector layer that are supposed to give the same resolutions I need.
>> I mean :
>>   Base layer (map) has scales in its options: [ 100000, 50000, 25000,
>> 10000, 5000, 2500, 1000, 500, 250, 100]
>>   Vector layer has scales in its options: [10000, 5000, 2500, 1000, 500,
>> 250, 100]
>>   So I expect the vector layer to have the good corresponding
>> resolutions, but it hasn't.  Maybe that is the issue.  Any thoughts ?
> Only the resolutions in your base layer are respected.  Individual
> resolution values on all overlay layers are ignored.  When your map
> changes resolution, layer.calculateInRange is called for each overlay
> layer.  If this returns false, the layer is not displayed.
> The layer.calculateInRange method checks layer.minResolution and
> layer.maxResolution.  If map.getResolution returns a value that is
> between the min/max for the layer (inclusive), calculateInRange returns
> true.  (The exception to this is when layer.alwaysInRange is true.)
> If you are encountering a situation where calculateInRange does not
> return the appropriate value, or if you think the precision in the scale
> to resolution conversion is not consistent, please start a new thread
> (this has nothing to do with vector layers or the cluster strategy).
> Tim
>> Alexandre
>> Eric Lemoine wrote:
>>> Hi Alexandre
>>> If you want your vector layer to be visible only for a subset of the
>>> base layer's resolutions you should set maxResolution and/or
>>> minResolution in your vector layer options.
>>> If you pass an array of resolutions to the vector layer, you can end
>>> up with vectorlayer.resolutions[i]  != baselayer.resolutions[i], where
>>> i is any index of the vector layer's resolutions array.
>>> And I think you are hitting the above case, which is making the
>>> cluster strategy doesn't behave as you expect it to.
>>> So I don't see anything wrong with the cluster strategy relying on
>>> this.layer.getResolution.
>>> I'd really like to hear what others think about that.
>>> Cheers,
>>> Eric
>>> 2008/11/7, Alexandre Dube <adube at mapgears.com>:
>>>> Hi devs,
>>>>   I got a problem using the cluster strategy.  At first, it didn't
>>>> seemed to work at all.  I always got the same number of feature with or
>>>> without the cluster strategy applied.  After a few search, I found out
>>>> the problem was at line 143 : *var* resolution =
>>>> *this*.layer.getResolution();
>>>>   I just replaced the line for : *var* resolution =
>>>> *this*.layer.map.getResolution(); and it worked.
>>>>   The reason is :
>>>>   My base layer has 10 fixed scales ( which gives 10 resolutions), from
>>>> 0 to 9.  My vector layer has only 7, which represents resolutions 3 to 9
>>>> of the base layer's scales, but the vector layer itself has his own
>>>> scales array from 0 to 6.  So, the line 143 which called resolution 3
>>>> from the base layer calls resolution 3 from the vector layer, which is
>>>> wrong !
>>>>   Anyone else noticed this ?
>>>> Alexandre Dubé
>>>> Mapgears
>>>> www.mapgears.com
>>>> _______________________________________________
>>>> Dev mailing list
>>>> Dev at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/dev
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Dev mailing list
