[OpenLayers-Dev] projection on geometry
    Eric Lemoine
    eric.c2c at gmail.com
    Wed Nov 12 00:40:36 EST 2008
This design makes sense to me.
Regarding the strategy: are you thinking of a projection strategy that
will listen on beforefeaturesadded and, if the layer proj isn't the
same as the map proj, will reproject the features before they're added
to the layer? Such a strategy would be useful when the data isn't read
through a format.
Eric
2008/11/11, Tim Schaub <tschaub at opengeo.org>:
> Hey-
> Picking up on the thread that Bart just referenced:
> http://www.mail-archive.com/dev@openlayers.org/msg02523.html
> I agree, we should keep track of projection at the geometry level.
> There are plenty of times that you have a geometry without a feature or
> a layer, and you want to maintain the srs info for that geometry.
> I've always thought this change would come with 3.0.  But it probably
> makes sense to start working it in to see how things go.
> Seems to me like we need a setter and getter.  So the following would work:
> polygon.setProjection(foo);
> polygon.components[0].components[0].getProjection(); // foo
> And it makes sense to me to push the work on to the setter (setting the
> same on all components), making access less work.
> I think it also makes sense to me that the layer does not set the
> geometry projection.  We assume that geometry projection is properly set
> before a feature is added to a layer.  This pushes the setting or
> transforming closer to the parsing (where it makes sense that you'd know
> the projection).
> In some cases, a format would do the transform (assuming
> internal/externalProjection are set).  In other cases, a strategy could
> do the transform (since it knows the map projection and the layer
> projection - where the layer projection should be set to match the source).
> I'm sure there's lots more to talk about.  This is what a sprint is good
> for.  Without that, it probably makes sense to get some code going and
> see where it takes us.  To this end, I've created a new sandbox [1].  I
> won't have any time for a bit to work on it, but I'll be happy to comment.
> Tim
> [1] http://svn.openlayers.org/sandbox/projection
> Tim Schaub
> OpenGeo - http://opengeo.org
> Expert service straight from the developers.
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev
