[OpenLayers-Dev] projection on geometry
Tim Schaub
tschaub at opengeo.org
Wed Nov 12 02:39:24 EST 2008
Hey-
bartvde at osgis.nl wrote:
> Hey Tim,
> are you saying that when a projection is set on a Polygon, it will be set
> on all the LinearRings as well? Is this really necessary? Or maybe I've
> misunderstood your approach ....
I could have been over thinking it. Since geometry.components is an API
property, I have no idea when people are grabbing points from polygons
(for example). I was also sort of thinking it might come in to play
when writing with a format - but now don't think that is a real issue
either.
So, maybe we just say if you are tearing apart geometries, you are
responsible for setting the projection property.
Tim
> To me it seems unlikely we will have a collection of geometries with
> different projections.
> Best regards,
> Bart
>> Hey-
>> Picking up on the thread that Bart just referenced:
>> http://www.mail-archive.com/dev@openlayers.org/msg02523.html
>> I agree, we should keep track of projection at the geometry level.
>> There are plenty of times that you have a geometry without a feature or
>> a layer, and you want to maintain the srs info for that geometry.
>> I've always thought this change would come with 3.0. But it probably
>> makes sense to start working it in to see how things go.
>> Seems to me like we need a setter and getter. So the following would
>> work:
>> polygon.setProjection(foo);
>> polygon.components[0].components[0].getProjection(); // foo
>> And it makes sense to me to push the work on to the setter (setting the
>> same on all components), making access less work.
>> I think it also makes sense to me that the layer does not set the
>> geometry projection. We assume that geometry projection is properly set
>> before a feature is added to a layer. This pushes the setting or
>> transforming closer to the parsing (where it makes sense that you'd know
>> the projection).
>> In some cases, a format would do the transform (assuming
>> internal/externalProjection are set). In other cases, a strategy could
>> do the transform (since it knows the map projection and the layer
>> projection - where the layer projection should be set to match the
>> source).
>> I'm sure there's lots more to talk about. This is what a sprint is good
>> for. Without that, it probably makes sense to get some code going and
>> see where it takes us. To this end, I've created a new sandbox [1]. I
>> won't have any time for a bit to work on it, but I'll be happy to comment.
>> Tim
>> [1] http://svn.openlayers.org/sandbox/projection
>> Tim Schaub
>> OpenGeo - http://opengeo.org
>> Expert service straight from the developers.
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
Tim Schaub
More information about the Dev
