[OpenLayers-Dev] problem with GML v2 parser
bartvde at osgis.nl
bartvde at osgis.nl
Thu Nov 13 10:45:19 EST 2008
Hi list,
I've got a slight problem with the GML v2 parser when running it over the
attached GML file. What I run into is that obj.attributes is undefined,
but I can't really find an explanation why this is happening ... and
ofcourse it would be good to know why instead of just patching it the way
I did below.
GML/Base.js, readers:
"_attribute": function(node, obj) {
var local = node.localName || node.nodeName.split(":").pop();
var value = this.getChildValue(node);
if (!obj.attributes) {
obj.attributes = {};
obj.attributes[local] = value;
I've also attached an example to reproduce the error.
/OpenLayers/Format/GML/Base.js
Line 342
TIA.
Best regards,
Bart
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20081113/2386784f/GMLparserv2.html
Type: text/xml
Desc: not available
Url : http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20081113/2386784f/kgn.xml
More information about the Dev
