[OpenLayers-Dev] Additional Documentation
    Tim Schaub
    tschaub at opengeo.org
    Thu Nov 13 13:19:34 EST 2008
Hey-
Christopher Schmidt wrote:
> Does anyone have any objections to creating trunk/doc/, putting some
> useful build utils in it, as well as creating subdirectories for
> individual prose documentation efforts, starting with the
> spherical_mercator.rst describe above?
No objections.  +1 for sure.
My only suggestion would be to consider Sphinx (and this can be
implemented later).  It adds a bit more structure to the HTML output -
and works well for (ordered) prose docs.
My biggest wiki-peeve (don't think this was on your list) is that a wiki
is completely unstructured.  Obviously there are conventions to impose
structure - but I think they tend toward chaos.  Sphinx works best with
a hierarchy and uses tables of contents in docs to determine
relationships between docs - and ultimately the order in which they
would be read were they part of a book.
Plus, the ".. code-block:: javascript" highlighting is nice (with
pygments).  And the PDF output (via LaTeX) is actually pretty.
Anyway, maybe the build stuff you have in mind is similar (or same).
Tim
> I'll start off by saying I'm +1.
> Regards,
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev
