[OpenLayers-Dev] problem with GML v2 parser
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Thu Nov 13 13:40:39 EST 2008
Hey Tim,
I've opened up:
http://trac.openlayers.org/ticket/1829
for this. Do you have any clue what could be the root cause of this error?
Best regards,
Bart
Tim Schaub wrote:
> Hey Bart-
> Thanks for the report. If you haven't already, could you attach your
> sample data to a ticket? It would be good to incorporate it into the
> test data when the issue is closed. (And we won't have to hunt for this
> email.)
> Tim
> bartvde at osgis.nl wrote:
>> Hi list,
>> I've got a slight problem with the GML v2 parser when running it over the
>> attached GML file. What I run into is that obj.attributes is undefined,
>> but I can't really find an explanation why this is happening ... and
>> ofcourse it would be good to know why instead of just patching it the way
>> I did below.
>> GML/Base.js, readers:
>> "_attribute": function(node, obj) {
>> var local = node.localName || node.nodeName.split(":").pop();
>> var value = this.getChildValue(node);
>> if (!obj.attributes) {
>> obj.attributes = {};
>> obj.attributes[local] = value;
>> I've also attached an example to reproduce the error.
>> /OpenLayers/Format/GML/Base.js
>> Line 342
>> TIA.
>> Best regards,
>> Bart
>> GML Parser Example
>> Demonstrate the operation of the GML parser.
>> This script reads data from a GML file and parses out the coordinates,
>> appending them to a HTML string with markup tags. This markup is dumped
>> to an element in the page.
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
More information about the Dev
