[OpenLayers-Dev] Cluster strategy should not process data when
layer is currently disabled (visibility=false)
Alexandre Dube
adube at mapgears.com
Thu Nov 13 15:34:06 EST 2008
Hi Eric, Ivan,
The following is enough to resolve the bug ( I think ).
##### patch ? start #####
--- Cluster.js.original 2008-11-13 14:05:25.000000000 -0500
+++ Cluster.js 2008-11-13 14:06:59.000000000 -0500
@@ -72,7 +72,7 @@
"beforefeaturesadded": this.cacheFeatures,
scope: this
- this.layer.map.events.on({"zoomend": this.cluster, scope:
this});
+ this.layer.events.on({"zoomend": this.cluster, scope: this});
return activated;
@@ -93,7 +93,7 @@
scope: this
- this.layer.map.events.un({"zoomend": this.cluster, scope:
this});
+ this.layer.events.un({"zoomend": this.cluster, scope: this});
return deactivated;
##### patch ? end #####
Trying that, I found an other bug which occurs with or without this fix.
If I pan to some place while the layer is not visible, then set it
back to visible, features won't appear. I'm not sure if that's because
my vector layer is not in the layerSwitcher. I toggle the vector
layer's visibility with a dummy layer, like this :
### code start ###
olDummy.events.register("visibilitychanged", olDummy, toggleVisibility);
function toggleVisibility()
var bVisible = this.getVisibility();
olWMS.setVisibility(bVisible);
olWFS.setVisibility(bVisible);
### code end ###
Ivan, could you test the behavior in your application ?
Best regards,
Alexandre
P.S. Being good at finding bugs is easy and not really rewarding...
Finding solutions, that's something ! You guys are doing great. Cheers !
Eric Lemoine wrote:
> You guys are good to find bugs :-)
> I think that, instead of listening to the map's zoomend events, the
> cluster strategy should listen to its layer's moveend events and check
> in the listener that this is actually a zoom change before doing
> anything. The moveend listener receives an object with a zoomChanged
> boolean property. Can one of you try modifying the cluster strategy
> with that and report back? (don't forget to change the unregistration
> as well).
> Thanks.
> Eric
> 2008/11/13, Ivan Grcic <ivan.grcic at geofoto.hr>:
>> Hi Alex,
>> i made a little hack to it...inside Strategy.Cluster.js inside cluster
>> function I added one more check:
>> (OpenLayers.Util.indexOf(this.layer.resolutions, resolution) != -1)
>> it doesnt do the clustering if current resolution is not contained
>> inside layers array of resolutions.
>> Index: Cluster.js
>> --- Cluster.js (revision 8317)
>> +++ Cluster.js (working copy)
>> @@ -141,7 +141,8 @@
>> cluster: function() {
>> if(this.features) {
>> var resolution = this.layer.map.getResolution();
>> - if(resolution != this.resolution || !this.clustersExist()) {
>> + if((OpenLayers.Util.indexOf(this.layer.resolutions,
>> resolution) != -1) && (resolution != this.resolution ||
>> !this.clustersExist())) {
>> this.resolution = resolution;
>> var clusters = [];
>> var feature, clustered, cluster;
>> Greetings,
>> Ivan
>> On Thu, Nov 13, 2008 at 3:02 PM, Alexandre Dube <adube at mapgears.com> wrote:
>>> I get the same behavior as Ivan's on my application which has very similar
>>> resolution settings on map an vector layer.
>>> Because a layer's features are not destroyed when it goes out of range
>>> (inRange) or becomes invisible (visibility), the cluster strategy still
>>> clusters those existing features. I don't have that many features to
>>> display
>>> when the layer becomes inRange, so I never noticed any slowing down.
>>> Alexandre
>>> Ivan Grcic wrote:
>>>> This post evolved from previous discussion named "bbox strategy and
>>>> zooming"
>>>> Clustering features with cluster strategy takes some time. If there
>>>> are many features to cluster, it will take even more time :)
>>>> So there are some scenarios where clustering shouldnt be recalculated.
>>>> Example:
>>>> I want to see my cluster layer only after 5th zoom level. No
>>>> clustering should be made when i play on zoom level 0-4 with other
>>>> layers,
>>>> because it slows things down, and the cluster layer is still not
>>>> visible at all (its only clustering features in background)
>>>> It should only cluster when layer is visible (and the current map
>>>> resolution is inside array resolution of clustered layer, if we define
>>>> seperate set of resolution)
>>>> So if map has:
>>>> resolutions: [0,1,2,3,4,5,6,7,8,9]
>>>> and vector layer:
>>>> resolutions: [5, 6, 7, 8, 9]
>>>> clustering should occur only on vector layers resolution :5, 6, 7, 8 and
>>>> 9.
>>>> I hope you see where im pointing now,
>>>> Best regards,
>>> Alexandre Dubé
>>> Mapgears
>>> www.mapgears.com
>> Ivan Grcic
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Dev
