[OpenLayers-Dev] Cluster strategy should not process data when layer is currently disabled (visibility=false)
Eric Lemoine eric.c2c at gmail.com
Fri Nov 14 11:51:42 EST 2008
On Thu, Nov 13, 2008 at 10:12 PM, Eric Lemoine <eric.c2c at gmail.com> wrote:
> Alexandre,
> Layers do not have the zoomend event type, so I don't think your patch
> is valid. Try with moveend and a check in the listener to handle zoom
> change only. Eric
Alexandre,
Could you apply the patches attached to #1831 et #1834 and report back?
Thanks,
http://trac.openlayers.org/ticket/1831
http://trac.openlayers.org/ticket/1834
Eric
More information about the Dev mailing list
