[OpenLayers-Dev] Layer.Vector: getStrategyByClass
Eric Lemoine
eric.c2c at gmail.com
Sun Nov 23 10:28:50 EST 2008
On Tue, Nov 18, 2008 at 9:38 AM, <bartvde at osgis.nl> wrote:
> Hi list,
> it would be convenient if the Vector Layer would have a getStrategyByClass
> function or not?
Yes it would.
> On a side note, should the getBy function of Map.js not be a Util one?
In that case it'd look like:
function(obj, array, property, match) {
var test = (typeof match.test == "function");
var found = OpenLayers.Array.filter(obj[array], function(item) {
return item[property] == match || (test && match.test(item[property]));
return found;
Given that Map.getBy is an API method it should remain. However it
could rely on the getBy function defined in Util.js:
getBy: function(array, property, match) {
return OpenLayers.Util.getBy(this, array, property, match)
I'm +1 on adding a getStrategyByClass method to the Layer.Vector
class and on adding a GetBy function to Util.js.
Thanks Bart,
Eric
More information about the Dev
