[OpenLayers-Dev] OpenLayers 3.0 Development
Christopher Schmidt crschmidt at metacarta.com
Mon Nov 24 07:45:01 EST 2008
On Mon, Nov 24, 2008 at 09:21:14AM +0100, Kenneth Skovhede, GEOGRAF A/S wrote:
> It sounds like a great idea, and it actually works for Python.
> However, since OpenLayers extensively use subclassing, won't this be
> a problem, if one were to make WFS3 it might be required to also make
> Layer3, Grid3, etc?
It might. If so, so be it, as far as I'm concerned.
> I can also see that the Map and Layer classes are tightly coupled, so I
> forsee trouble there. Will there be extra development to allow a Map3 to
> support a Layer, and vice versa for Layer3 and Map?
Not in my opinin -- this falls into the "We might not generate
alternatives for everything" category. If we need a new map, and the
layers need to behave differently, only updated layers will work (in the
same way only updated controls will work with newe vector layers, for
example).
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
