[OpenLayers-Dev] Problem with cluster strategy
Jerome Freyre
jerome.freyre at hispeed.ch
Thu Nov 27 02:24:42 EST 2008
Hi Eric,
yes it should work.
But is it not rather the work of the cluster strategy to calculate this
value?
Eric Lemoine-3 wrote:
> Hi Jérome
> What about registering a beforefeaturesadded listener and having this
> listener calculate the max value? That should do the trick...
> Eric
> 2008/11/26, Jerome Freyre <jerome.freyre at hispeed.ch>:
>> Hi Ivan,
>> Ok for the sample but the main goal of my post was a suggestion to
>> display
>> correctly the cluster on a map.
>> I think that the sample is not a correct representation of the reality.
>> The addition of a function that get the max value present permit to
>> display
>> correctly the cluster and have a radius that correspond to the reality.
>> In the sample formula, if you have a cluster that aggregate 100 features
>> and
>> an other that aggregate 20 feature they will be displayed with the same
>> radius.
>> With my function the radius will be correctly adapted and we have a
>> correct
>> Sincerly,
>> Jérome
>> Ivan Grcic-2 wrote:
>>> HI Jerome,
>>> Function Math.min(feature.attributes.count, 7) + 3 was just a sample
>>> in the demo. You can use whatever function you need, just take care to
>>> make it as simple as possible, because it runs trought it for every
>>> feature in cluster.
>>> Cheers, Ivan
>>> Ivan Grcic
>>> Dev mailing list
>>> Dev at openlayers.org
>>> http://openlayers.org/mailman/listinfo/dev
>> View this message in context:
>> http://www.nabble.com/Problem-with-cluster-strategy-tp20701364p20702430.html
>> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
>> Dev mailing list
> Dev mailing list
View this message in context: http://www.nabble.com/Problem-with-cluster-strategy-tp20701364p20714616.html
More information about the Dev
