[OpenLayers-Dev] firefox events problem
cozmotion
cozmotion at comcast.net
Thu Nov 27 15:38:18 EST 2008
Here's a simple file that shows the problem, or a very similar one.
Seems that the Vector Layers have a higher z-index and are not passing the
mouse events through to the Markers(?)
In any case, setting the markers' z-index above the vectors solves the
problem
(See the code and uncomment the section at the bottom to see the
work-around.
line_test2.html - link below
ethan919 wrote:
> Dear listers!
> I have a problem about trigger event on firefox2.0, Currently I'm
> using openlayers-2.5,and construct a marker like this:
> var marker = new OpenLayers.Marker(lonlat);
> marker1.events.register("mouseover", marker1, function(evt)
> alert("test");
> Event.stop(evt); });
> markers.addMarker(marker1);
> when I use IE7,there is no problem,I can see the alert window,but when I
> use
> firefox2.0,it seems like the event never fired,nothing happend on the
> screen.Did anyone encounter the same problem,or it's just my code's
> problem,Am I missing anything about events.Thanks for any kind of help!
http://www.nabble.com/file/p20725298/line_test2.html line_test2.html
View this message in context: http://www.nabble.com/firefox-events-problem-tp14432333p20725298.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
