[OpenLayers-Dev] [OpenLayers-Users] OL-Based GeoEditor
bartvde at osgis.nl
bartvde at osgis.nl
Fri Nov 28 07:13:05 EST 2008
AFAIK there is no javascript library for this.
As Carsten writes they use a Java backend based on JTS for this, which is
a pretty logical solutions.
If you look at the WPSDemo by Chris you'll see something similar. which
uses Python and GEOS on the server-side.
http://crschmidt.net/mapping/wpserverdemo/
Best regards,
Bart
> Yves,
> This sounds interesting. I have a need to select a group or collection of
> polygons from a user who just clicks the polygons they need. Then I need
> to aggregate all the geometries into a single object and also aggregate
> the numeric attributes. Then to insert the new geometry into the database
> as a WFS-T transaction. So far my OL application can get all the polygons
> and all the attributes with WFS but have not got software to aggregate the
> geometries. Would you have the javascript software to do this?
> Cheers, Bradâ¦
> From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
> On Behalf Of Dipl. Inf. Carsten Eider
> Sent: Friday, November 28, 2008 9:13 PM
> To: Yves Moisan
> Cc: users at openlayers.org; dev at openlayers.org
> Subject: Re: [OpenLayers-Users] OL-Based GeoEditor
> Hi Yves,
> thank you for your answer, i hope other people also had some fun with
> this nice tool!
> What ist your impresiion of it? Could it be usable?
> Are there any other testers or has someone else a feedback (either
> negative or positive) for me?
> English UI: Our development-focus is set on german farmers, so there is no
> need to use an english one!
> But if there is a big demand for it, i will do it, or better let it do:-)
> thx Carsten
> Yves Moisan schrieb:
> I like the gröSSe option :-). An English UI would help me as a French
> speaker. Mein Deutsch nicht sehr gut ist :-)
> Yves
> Le jeudi 27 novembre 2008 Ã 15:44 +0100, Dipl. Inf. Carsten Eider a
> écrit :
> Hi list,
> my work on a GeoEditor is nearly completely done.
> Features:
> * using Openlayers for geometric operations, only joining and
> splitting is done by a JTS-Java-Backend
> * using WFS-T with a GeoServer(Shapefile as backend) for storing
> the changes
> * using SLD and handmade Java-BackEnd for storing LayerStyles
> * using dojo for editing styles.
> Restrictions:
> * only german front-end
> Proof-of-concept:
> * https://143.93.78.98/geoEditor2/editor.html, use "demo" and no
> password for login
> Thx Carsten
> Dipl. Inf. Carsten Eider schrieb:
> Hi folks,
> i am working on a small geo-editor for an agricultural project in
> rhine-palatinat/germany, visit http://www.agroconnect.de for more
> information.
> Upto now my editor has the following features:
> * new polygon, plain OL
> * edit polgon, plain OL
> * delete polygon, plain OL
> * union polygon, OL with a javaserver in the backend
> Coming feaures:
> * split polygon into 2 elements, OL with server backend
> * group polygons
> At the moment i am hanging a bit with the split-feature.
> My idea is
> 1. select polygon
> 2. select first point/vertix as starting point
> 3. select second point as ending point
> 4. do split
> 5. remove polygon and add the new ones
> Step 4 will be done on serverside,but could also be done on
> clientside.
> Any ideas how to realize steps 1-3. Should i use several controls
> (Select and Modify) or
> should i subclass Control.ModifyFeature ?
> Any hints will be appreciated.
> Mit freundlichen GrüÃen / Yours faithfully
> Carsten Eider
> Dipl. Inf. (FH)
> Kompetenzzentrum für Innovative Informationssysteme
> c/o Fachhochschhule Bingen / University of applied sciences Bingen
> BerlinstraÃe 109
> 55411 Bingen
> Tel: +49 (0) 6721 / 409-179
> Fax: +49 (0) 6721 / 409-158
> email: eider at fh-bingen.de
> Internet: iis.fh-bingen.de
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
> Carsten Eider
> Dipl. Inf. (FH)
> BerlinstraÃe 109
> 55411 Bingen
> Users mailing list
> Carsten Eider
> Dipl. Inf. (FH)
> BerlinstraÃe 109
> 55411 Bingen
> Users mailing list
More information about the Dev
