[OpenLayers-Dev] openlayers problem in IE6
Nathan Gerber
ngerber999 at gmail.com
Fri Oct 17 11:36:48 EDT 2008
If you are using PNG images this is a known issue and there is little you
can do beyond trying another format such as GIF or telling your users to get
a more modern web browser. There is a hack to enable the use of alpha
transparency int he PNG images within IE6 but it has a severe effect on
performance.
Nathan Gerber
2008/10/16 dequan chen <cdqrain at gmail.com>
> hi.
> I use more than one openlayers vector layer to overlay the map. every layer
> has its event. in IE6, the upper layer covers completely the lower layer.
> so, the other vector layer event can not be triggered. in IE7 or firefox,
> there's no this issue.
> I try to render the vector layer div border, and find the div fill the
> entire map. in IE7 or firefox, the border shrinks to the top left corner.
> so the layer don't cover the lower layer.
> how to solve this problem ? thanks. :-)
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20081017/7d5aa935/attachment.html
More information about the Dev
