[OpenLayers-Dev] Ticket #1359: spelling mistake?
Erik Uzureau euzuro at gmail.com
Thu Oct 23 18:16:08 EDT 2008
patch added, ticket up for review
http://trac.openlayers.org/attachment/ticket/1359/propagate.patch
can you let us know if that fixes your problem?
erik
On Thu, Oct 23, 2008 at 5:04 PM, Erik Uzureau <euzuro at gmail.com> wrote:
> good find, chris. indeed a bug. i've reopened the ticket and am preparing a
> patch:
> http://trac.openlayers.org/ticket/1359#comment:12
> On Thu, Oct 23, 2008 at 4:47 PM, Chris Rankin <rankincj at yahoo.com> wrote:
>> Hi,
>> I have noticed the following oddity in a patch attached to ticket #1359,
>> at line 152:
>> http://trac.openlayers.org/attachment/ticket/1359/rightClicks.patch
>>        144             var propagate = true;
>>        145
>>        146             // Collect right mouse clicks from the mouseup
>>        147             //  IE - ignores the second right click in
>> mousedown so using
>>        148             //  mouseup instead
>>        149             if (this.checkModifiers(evt) &&
>>        150                 this.control.handleRightClicks &&
>>        151                 OpenLayers.Event.isRightClick(evt)) {
>>        152               propogate = this.rightclick(evt);
>>        153             }
>>        154
>>        155             return propagate;
>> Surely that should be "propagate" rather than "propogate"?
>> Cheers,
>> Chris
>> P.S. Is there any reason why the following would NOT notify me of
>> right-clicks on my map?
>>            map.events.register('rightclick', map, function(e) {
>>                alert(this.CLASS_NAME);
>>                return true;
>> I have already set the handleRightClicks property to "true" on the
>> Navigation control.
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20081023/d50ebd25/attachment.html
More information about the Dev mailing list
