[OpenLayers-Dev] Format.WMC and scale
Eric Lemoine
eric.c2c at gmail.com
Mon Oct 27 02:40:00 EDT 2008
Hi Bart
We've also experienced unexpected minScale/maxScale values here at
Camptocamp. So far we haven't had a chance to investigate the problem.
On your side have you figured out why the calculated minScale is
different than the minScale value in the options?
Regarding WMC, I think it makes that WMC write uses layer.minScale.
Indeed, we need to deal with cases where the layer wasn't built out of
WMC and no minScale option was set in the layer.
Eric
2008/10/23, bartvde at osgis.nl <bartvde at osgis.nl>:
> Hi list,
> question about the Format.WMC code.
> When it reads a scale from a WMC doc, it is stored in the options array of
> the layer.
> But when it writes, it uses the minScale or maxScale property of the layer.
> Why is this? I would expect when writing to also use the options.minScale
> and options.maxScale.
> In my situation options.minScale is 35000 (the correct value) and
> layer.minScale is 10000000.999999998, don't ask me why :-). So when
> serializing the WMC the wrong information is written.
> Best regards,
> Bart
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev
