[OpenLayers-Dev] OpenLayers.Strategy.Cluster() - feature.geometry is null
Ivan Grcic ivan.grcic at geofoto.hr
Mon Oct 27 11:45:45 EDT 2008
Hi list (or should i say hi Eric :)
I have a problem with using cluster strategy. I use gml file exported
with geoserver getFeature request to display my vector layer.
When using "normal" gml layer i get my features displayed without
problem, so i guess that means my GML file is valid:
myGmlLayer= new OpenLayers.Layer.GML("My name", "fileFromGeoserver.gml");
When using that same file but with cluster strategy, i get following
error in my firebug window
                         OpenLayers.js (line 535)
return exist;},shouldCluster:function(cl...ck:this.merge,scope:this});return
true;}
this is my code for cluster layer:
    var style = new OpenLayers.Style({
        pointRadius: "${radius}",
        context: {
          radius: function(feature) {
			return Math.min(feature.attributes.count,4) + 3;
	myGmlLayer= new OpenLayers.Layer.Vector("GML", {
					strategies: [new OpenLayers.Strategy.Fixed(), new
OpenLayers.Strategy.Cluster()],
                    protocol: new OpenLayers.Protocol.HTTP({
						url: "fileFromGeoserver.gml",
                        format: new OpenLayers.Format.GML()
		    styleMap:new OpenLayers.StyleMap({
                          "default": style,
Should my features inside gml file have some particular syntax for
geometry column? Hmm i dont think so, because it gets displayed
properly with OpenLayers.Layer.GML...
Any thoughts about it? I can post a bit of gml file if necessary..
Regards,
Ivan
More information about the Dev mailing list
