[OpenLayers-Dev] Problem with the developpement of a "overlay
Strategy"
Tim Schaub
tschaub at opengeo.org
Mon Oct 27 22:50:01 EDT 2008
Hey-
Jerome Freyre wrote:
> Hi everybody,
> Currently I am trying to developp a new strategy (based on
> OpenLayers.Strategy.Cluster) that can modify the order of features (bigger
> features go downer and small one go higher) to display features with correct
> "overlay" or "superposition".
> To do that, I found that I have to order my features.
> Actually, I am loading my features with HTTP protocol (see:
> http://www.nabble.com/Problem-with-Protocol-HTTP-and-vector-layer-tt20088456.html
> My "sort algorithm" seems to work because it is ordering features based on
> the "overlayAttribute".
> The problem appears when I select a feature that is "downer". When I
> unselect it, the feature goes "higher" than the smaller one and stays like
> this.
Sounds like this could be accomplished with rule based styling.
You could set the graphicZIndex property of a symbolizer based on your
feature attributes.
See the ordering example for use of graphicZIndex.
http://openlayers.org/dev/examples/ordering.html
See the StyleMap example for use of rule based styling.
http://openlayers.org/dev/examples/stylemap.html
For a convenience method to deal with unique value rules, see the unique
styles example.
http://openlayers.org/dev/examples/styles-unique.html
And, if a 1:1 mapping between attribute values and z-index doesn't work
for you, you might be able to use the context based symbolizer evaluation.
http://openlayers.org/dev/examples/styles-context.html
Finally, if you do need to sort your features, your strategy should set
the graphicZIndex property.
Tim
> Has somebody got an idea to resolve this problem?
> My strategy function :
> if(this.features.length >= 2) {
> var tempArray = this.features;
> //alert('count = ' + this.features.length);
> for (var i=0; i<this.features.length; i++) {
> for(var j=this.features.length-1; j>i;j--) {
> //alert('Comparaison de ' +
> this.features[j].attributes[this.overlayAttribute] + ' et ' +
> this.features[j-1].attributes[this.overlayAttribute]);
> if (parseInt(this.features[j].attributes[this.overlayAttribute]) >
> parseInt(this.features[j-1].attributes[this.overlayAttribute])) {
> var tmp = this.features[j];
> this.features[j] = this.features[j-1];
> this.features[j-1] = tmp;
> var attr = "";
> for(var i=0; i<this.features.length; ++i) {
> attr += this.features[i].attributes[this.overlayAttribute] + ' \\ ';
> if(this.features.length > 0) {
> this.clustering = true;
> // A legitimate feature addition could occur during this
> // addFeatures call. For clustering to behave well,
> features
> // should be removed from a layer before requesting a new
> batch.
> this.layer.removeFeatures();
> this.layer.addFeatures(this.features);
> this.clustering = false;
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev
