[OpenLayers-Dev] How to modify GML style
Alexandre Dube
adube at mapgears.com
Tue Sep 9 08:00:42 EDT 2008
Hi Gorka,
You can style your features with a StyleMap object. Here's an example
using a WFS layer, but this is pretty much the same as GML, since both
are vector layers.
// styleMap for region
oRegStyleMap = new OpenLayers.StyleMap({
strokeColor: "black",
strokeWidth: 2,
strokeOpacity: 1
fillOpacity: 0.3,
fillColor:"purple"
// region WFS layer, contains polygon features
olWFSReg = new OpenLayers.Layer.WFS(
"Régions admin. - WFS",
sMSURL,
typename: "BDGA_REGIO_S_POLY_1M",
map: sBDGAMapPath
extractAttributes: true,
styleMap: oRegStyleMap // <------
Hope this helps,
Alexandre
Gorka López Rivacoba wrote:
> Hello,
> I'm loading a route with GML in my map, but the line which appears
> (the yellow one) is too similar to my map. I'm reading the code, but I
> don't find any solution
> Is there any solution to modify the style of these lines?
> Thanks a lot. Regards,
> Gorka López
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Dev
