[OpenLayers-Dev] Event trapping by dragging... on Boxes...
    Garthan
    lancelot at inetnebr.com
    Tue Sep 16 17:31:35 EDT 2008
In case you are wondering a reason to use the retro Box
its a lot less code (vector requires a bunch of renderer specifics.. )
and I would rather have a smaller build.
I think I will "for my use" put the listener on the map and run through
the comparisons of the box extents this may even allow me to handle
special cases of boxes which overlap one another. (like give a list)
Garthan wrote:
> Actually see the page with the div based box markers...
> In some ways the opposite problem as the issue of Vectors --- basically
> the drag events up is registered as the end
> of click event... no matter how much time
> has passed from the mousedown event...
> Huey Brantley wrote:
>> I may be wrong but I think he is seeing the same issue and me.  I have
>> a vector layer (GML) on top of my map. The vector layer has a
>> selectFeature control attached to it.  If you click and hold, intended
>> to pan, while over the polygon, it won't pan.  Also, if hover is
>> activated and a popup is drawn, clicking triggers a error in FireBug.
>> On Tue, Sep 16, 2008 at 9:19 AM, Christopher Schmidt
>> <crschmidt at metacarta.com> wrote:
>>> On Mon, Sep 15, 2008 at 09:11:32PM -0500, Lance Dyas wrote:
>>>> Christopher Schmidt wrote:
>>>> >On Mon, Sep 15, 2008 at 07:43:57PM -0500, Lance Dyas wrote:
>>>> >>Im having some difficulties with the drag action fires a click event
>>>> >>if it ends on a box... so my user intending to drag the view gets a
>>>> >>click event?
>>>> >>if his mouse down and mouse up are both over the box.
>>>> >>You can see the effect in the standard boxes examples
>>>> >>it isnt much of a problem if your click event is innocuous
>>>> >>like changing the box color... but for something like opening
>>>> >>a popup or page change or something more real
>>>> >>this is a very bad thing.
>>>> >Use a Click Handler.
>>>> I am feeling dense today.. so maybe its obvious  but how do I use a
>>>> ClickHandler
>>>> on something other than the map itself (the boxes in the basic example
>>>> would be nice)?
>>>> Do I need to trap the event on the map and run through the boxes to
>>>> fire
>>>> click event
>>>> based on a bounds test of those?
>>>> If you have to go through hoops to make this function in a more
>>>> natural way it might be nice to have an example of it.
>>> Er, I don't understand. What is your click event registered on? 'Boxes'
>>> in
>>> OpenLayers dont' have an OpenLayers.Events class attached to them, so I
>>> don't understand how you could be registering a click event on them in
>>> OpenLayers-land...
>>> Regards,
>>> Christopher Schmidt
>>> MetaCarta
>>> Dev mailing list
>>> Dev at openlayers.org
>>> http://openlayers.org/mailman/listinfo/dev
>> Dev mailing list
View this message in context: http://n2.nabble.com/Event-trapping-by-dragging...--on-Boxes...-tp1091638p1093757.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
