[OpenLayers-Dev] Event trapping by dragging... on Boxes...
Christopher Schmidt crschmidt at metacarta.com
Tue Sep 16 18:13:22 EDT 2008
On Tue, Sep 16, 2008 at 01:58:04PM -0500, Huey Brantley wrote:
> Wiki says:
> You can add the following lines to allow for dragging the map when
> your mouse cursor is over a feature:
> Question is, add them to where?  The selectFeature control js or to
> your map code.  I would assume this would be added to the control
> code.
No, just to your application code, after creating the selectFeature
control.
> On Tue, Sep 16, 2008 at 12:01 PM, Christopher Schmidt
> <crschmidt at metacarta.com> wrote:
> > On Tue, Sep 16, 2008 at 11:16:33AM -0500, Huey Brantley wrote:
> >> I may be wrong but I think he is seeing the same issue and me.  I have
> >> a vector layer (GML) on top of my map. The vector layer has a
> >> selectFeature control attached to it.  If you click and hold, intended
> >> to pan, while over the polygon, it won't pan.
> > http://faq.openlayers.org/vector-related-questions/why-cant-i-drag-the-map-when-my-mouse-is-over-a-vector-feature/
> >> Also, if hover is
> >> activated and a popup is drawn, clicking triggers a error in FireBug.
> > Suggest narrowing this one down to a minimal test case and opening a
> > ticket.
> > Regards,
> > Christopher Schmidt
> > MetaCarta
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
