[OpenLayers-Dev] Development regarding WFS layer/protocol
Tim Schaub
tschaub at opengeo.org
Thu Sep 25 12:24:29 EDT 2008
Hello-
Julien-Samuel Lacroix wrote:
> HI,
> We work with WFS on a daily basis, but not with transactional. Does that
> patch apply to us as well? If so, we would be happy to help.
Yes, the WFS protocol is of use to anyone using WFS. You should be able
to confirm that a filter added to a layer with the WFS protocol will be
serialized in the body of a GetFeature POST (ack).
Thanks for any help in reviewing/testing.
Tim
> Julien
> Tim Schaub wrote:
>> Hey-
>> So, tests are now passing with the WFS protocol. I think this is
>> pretty close and would appreciate any help creating tests, trying it
>> out, etc.
>> The patch [1] includes a very basic Save strategy. This is a manual
>> save strategy (requires that you call save). It can be used as the
>> basis for auto or greedy save strategies, but I think we should keep
>> it simple for this patch.
>> Thanks for any assistance testing/reviewing.
>> Tim
>> [1] http://trac.openlayers.org/ticket/1648
>> Tim Schaub wrote:
>>> Hey-
>>> I put up a patch that represents progress towards a working WFS
>>> protocol.
>>> I'll work on it a bit more tomorrow. Please feel free to pick it up
>>> and push it forward (anyone). The wfs-protocol-transactions.html
>>> example is a good place to start with a debugger. In the end, this
>>> example will do inserts, updates, and deletes (with a commit from the
>>> save button).
>>> Tim
>>> Björn Harrtell wrote:
>>>> I have been making a serious (relatively? :) attempt at
>>>> understanding what is to be done regarding Protocol.WFS and related
>>>> classes. I looked at it from the angle in which it would be useful
>>>> for me in the case I described before.
>>>> * the standard WFS-T
>>>> * Fixed and Save (and perhaps SaveGreedy) strategy
>>>> From I can gather none of these are far from complete, but what I'm
>>>> missing is option to filter the input in Fixed strategy. I noticed
>>>> that the trunk version of BBOX strategy looks for additional filters
>>>> in the layer and while it might be a good place put the additional
>>>> filter I can't see any indication that Layer actually is supposed to
>>>> support such a property. If it should it should be documented and
>>>> used by fixed strategy also?
>>>> I would like to to implement this before beeing able to do serious
>>>> testing. I nice thing is that I could test stuff directly in a real
>>>> world case where I'm using (successfully) the clumsy old Layer.WFS
>>>> way with a temp layer. But before that I would like to confirm that
>>>> I got the right idea...
>>>> A question on the side... why are some methods declared "JSONy" i.e
>>>> 'read' instead of read?
>>>> /Björn
>>>> On Wed, Sep 17, 2008 at 2:10 AM, Tim Schaub <tschaub at opengeo.org
>>>> <mailto:tschaub at opengeo.org>> wrote:
>>>> Hey-
>>>> > Hi devs,
>>>> > I'm coding an application that uses OL vector editing and WFS
>>>> > transactions quite heavily.
>>>> > I use a temporary OpenLayers.Layer.Vector for editing, moving
>>>> stuff to a
>>>> > OpenLayers.Layer.WFS as the user makes edits. This is a bit
>>>> clumsy and
>>>> > complicated but works. The reason why I'm doing this is because
>>>> > OpenLayers.Layer.WFS only supports GET and is also loading
>>>> features on
>>>> > demand (hmm is this correct?) which doesn't fit my needs. Note
>>>> that I do
>>>> > not add the OpenLayers.Layer.WFS to a map, I only use
>>>> create/commit the
>>>> > WFS transactions.
>>>> > I would like to use something like a static/manually triggered
>>>> WFS
>>>> > (supporting POST and filtering) source to an
>>>> > that syncs changes to the WFS source which then can be commited
>>>> > programmatically.
>>>> > Is this sort of what OpenLayers.Protocol.WFS (which I think is
>>>> beeing
>>>> > worked on?) is supposed to be used for? Or would it be sensible
>>>> to make
>>>> > something more of OpenLayers.Layer.WFS instead?
>>>> Yes, this is exactly the job for a WFS protocol. As Eric
>>>> mentions, the
>>>> work is mostly in the vector-behavior sandbox. I'll make an
>>>> effort to
>>>> update that and to get a patch ready for the trunk.
>>>> My hope is to get the WFS protocol in the trunk before the end of
>>>> next
>>>> week. Any help you can contribute would be appreciated.
>>>> Watch the WFS protocol ticket [1] for updates from me, and leave any
>>>> comments/patches there that you put together.
>>>> Tim
>>>> > Either way, I'm interested in (trying) to help out if this
>>>> seems like
>>>> > something you would like to support in OL, and can probably do it
>>>> as a
>>>> > part of the current project as it would simplify things for me I
>>>> think.
>>>> > Regards,
>>>> > Björn Harrtell
>>>> > GIS Consultant
>>>> > SWECO Position AB
>>>> <http://www.swecogroup.com/en/Sweco-group/Services/Geographic-IT/>
>>>> > _______________________________________________
>>>> > Dev mailing list
>>>> > Dev at openlayers.org <mailto:Dev at openlayers.org>
>>>> > http://openlayers.org/mailman/listinfo/dev
>>>> Tim Schaub
>>>> OpenGeo - http://opengeo.org
>>>> Expert service straight from the developers.
>>>> Dev mailing list
Tim Schaub
More information about the Dev
