[OpenLayers-Dev] Drawing on curves
Christopher Schmidt crschmidt at metacarta.com
Fri Sep 26 07:21:13 EDT 2008
On Fri, Sep 26, 2008 at 10:20:36AM +0200, Gianni Barrotta wrote:
> Hi list,
> I implemented a function that extracts all the features inside a buffer
> calulated with oracle spatial around a feature.
> The buffer is represented in WKT (CURVEPOLYGON).
> It seems that the WKT adapter in OL isn't able to draw curves, so how can I
> manage this issue?
> I've found this thicket:
> http://trac.openlayers.org/ticket/1715
> is it what I need to draw a CURVEPOLYGON?
CURVEPOLYGON doesn't exist in the WKT Spec (afaik). Is there a tool to
convert from curves to regular polygons? I've seen that path followed in
the past.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
