[OpenLayers-Dev] Patch for building with python 3.0.1
Kris Geusebroek kgeusebroek at xebia.com
Thu Apr 2 04:32:40 EDT 2009
Skipped content of type multipart/related-------------- next part --------------
Index: D:/projects/xebia/vtsPolitie/workspace/openlayers/build/build.py
--- D:/projects/xebia/vtsPolitie/workspace/openlayers/build/build.py	(revision 9165)
+++ D:/projects/xebia/vtsPolitie/workspace/openlayers/build/build.py	(working copy)
@@ -12,8 +12,8 @@
     try:
         import minimize
         have_compressor = "minimize"
-    except Exception, E:
-        print E
+    except Exception as E:
+        print(E)
         pass
 sourceDirectory = "../lib"
@@ -30,21 +30,21 @@
 if len(sys.argv) > 2:
     outputFilename = sys.argv[2]
-print "Merging libraries."
+print("Merging libraries.")
 merged = mergejs.run(sourceDirectory, None, configFilename)
 if have_compressor == "jsmin":
-    print "Compressing using jsmin."
+    print("Compressing using jsmin.")
     minimized = jsmin.jsmin(merged)
 elif have_compressor == "minimize":
-    print "Compressing using minimize."
+    print("Compressing using minimize.")
     minimized = minimize.minimize(merged)
 else: # fallback
-    print "Not compressing."
+    print("Not compressing.")
     minimized = merged
-print "Adding license file."
-minimized = file("license.txt").read() + minimized
+print("Adding license file.")
+minimized = open("license.txt").read() + minimized
-print "Writing to %s." % outputFilename
-file(outputFilename, "w").write(minimized)
+print("Writing to %s." % outputFilename)
+open(outputFilename, "w").write(minimized)
-print "Done."
+print("Done.")
Index: D:/projects/xebia/vtsPolitie/workspace/openlayers/build/buildUncompressed.py
--- D:/projects/xebia/vtsPolitie/workspace/openlayers/build/buildUncompressed.py	(revision 9165)
+++ D:/projects/xebia/vtsPolitie/workspace/openlayers/build/buildUncompressed.py	(working copy)
@@ -14,12 +14,12 @@
 merged = file("license.txt").read() + merged
 file(outputFilename, "w").write(merged)
-print "Done."
+print("Done.")
Index: D:/projects/xebia/vtsPolitie/workspace/openlayers/tools/exampleparser.py
--- D:/projects/xebia/vtsPolitie/workspace/openlayers/tools/exampleparser.py	(revision 9165)
+++ D:/projects/xebia/vtsPolitie/workspace/openlayers/tools/exampleparser.py	(working copy)
@@ -53,7 +53,7 @@
     returns html of a specific example that is available online or locally
-    print '.',
+    print('.', end=" ")
     if location.startswith('http'):
         return urllib2.urlopen(location).read()
     else:
@@ -180,8 +180,8 @@
                 for word in words:
                     if word:
                         word = word.lower()
-                        if index.has_key(word):
-                            if index[word].has_key(i):
+                        if word in index:
+                            if i in index[word]:
                                 index[word][i] += 1
                             else:
                                 index[word][i] = 1
@@ -192,7 +192,7 @@
 if __name__ == "__main__":
     if missing_deps:
-        print "This script requires simplejson and BeautifulSoup. You don't have them. \n(%s)" % E
+        print("This script requires simplejson and BeautifulSoup. You don't have them. \n(%s)" % E)
         sys.exit()
     if len(sys.argv) > 1:
@@ -201,7 +201,7 @@
         outFile = open('../examples/example-list.js','w')
     examplesLocation = '../examples'
-    print 'Reading examples from %s and writing out to %s' % (examplesLocation, outFile.name)
+    print('Reading examples from %s and writing out to %s' % (examplesLocation, outFile.name))
     exampleList = []
     docIds = ['title','shortdesc']
@@ -227,7 +227,7 @@
         exampleList.append(tagvalues)
-    print
+    print()
     exampleList.sort(key=lambda x:x['example'].lower())
@@ -239,13 +239,13 @@
     outFile.write(json)
     outFile.close()
-    print "writing feed to ../examples/%s " % feedName
+    print("writing feed to ../examples/%s " % feedName)
     atom = open('../examples/%s' % feedName, 'w')
     doc = createFeed(exampleList)
     atom.write(doc.toxml())
     atom.close()
-    print 'complete'
+    print('complete')
Index: D:/projects/xebia/vtsPolitie/workspace/openlayers/tools/toposort.py
--- D:/projects/xebia/vtsPolitie/workspace/openlayers/tools/toposort.py	(revision 9165)
+++ D:/projects/xebia/vtsPolitie/workspace/openlayers/tools/toposort.py	(working copy)
@@ -103,7 +103,7 @@
         try:
             newdependencylevel, object = dependencies.get ( depends, (0, depends))
         except TypeError:
-            print depends
+            print(depends)
             raise
         dependencies[ depends ] = (newdependencylevel + 1,  depends)
         # "dependency (existence) of depended-on"
@@ -116,8 +116,8 @@
     ### Now we do the actual sorting
     # The first task is to create the sortable
     # list of dependency-levels
-    sortinglist = dependencies.values()
-    sortinglist.sort ()
+    sortinglist = sorted(dependencies.values())
+    #sortinglist.sort ()
     output = []
     while sortinglist:
         deletelist = []
@@ -160,10 +160,10 @@
             except KeyError:
                 pass
         # need to recreate the sortinglist
         if not generation:
             output.remove( generation )
     return output
@@ -177,7 +177,7 @@
     for x in  toposort( nodes, route):
         for a in x:
-            print a
+            print(a)
     raise SystemExit
@@ -227,34 +227,34 @@
             (3,1),
-    print 'sort, no recursion allowed'
+    print('sort, no recursion allowed')
     for index in range(len(testingValues)):
-##        print '    %s -- %s'%( index, testingValues[index])
+##        print('    %s -- %s'%( index, testingValues[index]))
         try:
-            print '        ', sort( nodes, testingValues[index] )
+            print('        ', sort( nodes, testingValues[index] ))
         except:
-            print 'exception raised'
-    print 'toposort, no recursion allowed'
+            print('exception raised')
+    print('toposort, no recursion allowed')
         try:
-            print '        ', toposort( nodes, testingValues[index] )
+            print('        ', toposort( nodes, testingValues[index] ))
         except:
-    print 'sort, recursion allowed'
+    print('sort, recursion allowed')
         try:
-            print '        ', sort( nodes, testingValues[index],0 )
+            print('        ', sort( nodes, testingValues[index],0 ))
         except:
-    print 'toposort, recursion allowed'
+    print('toposort, recursion allowed')
         try:
-            print '        ', toposort( nodes, testingValues[index],0 )
+            print('        ', toposort( nodes, testingValues[index],0 ))
         except:
Index: D:/projects/xebia/vtsPolitie/workspace/openlayers/tools/mergejs.py
--- D:/projects/xebia/vtsPolitie/workspace/openlayers/tools/mergejs.py	(revision 9165)
+++ D:/projects/xebia/vtsPolitie/workspace/openlayers/tools/mergejs.py	(working copy)
@@ -74,7 +74,7 @@
     Displays a usage message.
-    print "%s [-c <config file>] <output.js> <directory> [...]" % filename
+    print("%s [-c <config file>] <output.js> <directory> [...]" % filename)
 class Config:
@@ -151,12 +151,12 @@
     ## Import file source code
     ## TODO: Do import when we walk the directories above?
     for filepath in allFiles:
-        print "Importing: %s" % filepath
+        print("Importing: %s" % filepath)
         fullpath = os.path.join(sourceDirectory, filepath)
         content = open(fullpath, "U").read() # TODO: Ensure end of line @ EOF?
         files[filepath] = SourceFile(filepath, content) # TODO: Chop path?
-    print
+    print()
     from toposort import toposort
@@ -168,7 +168,7 @@
         nodes = []
         routes = []
         ## Resolve the dependencies
-        print "Resolution pass %s... " % resolution_pass
+        print("Resolution pass %s... " % resolution_pass)
         resolution_pass += 1
         for filepath, info in files.items():
@@ -179,8 +179,8 @@
         for dependencyLevel in toposort(nodes, routes):
             for filepath in dependencyLevel:
                 order.append(filepath)
-                if not files.has_key(filepath):
+                if not filepath in files:
@@ -197,34 +197,34 @@
         except:
             complete = False
-        print
+        print()
     ## Move forced first and last files to the required position
     if cfg:
-        print "Re-ordering files..."
+        print("Re-ordering files...")
         order = cfg.forceFirst + [item
                      for item in order
                      if ((item not in cfg.forceFirst) and
                          (item not in cfg.forceLast))] + cfg.forceLast
-    print
+    print()
     ## Output the files in the determined order
     result = []
     for fp in order:
         f = files[fp]
-        print "Exporting: ", f.filepath
+        print("Exporting: ", f.filepath)
         result.append(HEADER % f.filepath)
         source = f.source
         result.append(source)
         if not source.endswith("\n"):
             result.append("\n")
-    print "\nTotal files merged: %d " % len(files)
+    print("\nTotal files merged: %d " % len(files))
     if outputFilename:
-        print "\nGenerating: %s" % (outputFilename)
+        print("\nGenerating: %s" % (outputFilename))
         open(outputFilename, "w").write("".join(result))
     return "".join(result)
@@ -247,6 +247,6 @@
     configFile = None
     if options and options[0][0] == "-c":
         configFile = options[0][1]
-        print "Parsing configuration file: %s" % filename
+        print("Parsing configuration file: %s" % filename)
     run( sourceDirectory, outputFilename, configFile )
Index: D:/projects/xebia/vtsPolitie/workspace/openlayers/tools/shrinksafe.py
--- D:/projects/xebia/vtsPolitie/workspace/openlayers/tools/shrinksafe.py	(revision 9165)
+++ D:/projects/xebia/vtsPolitie/workspace/openlayers/tools/shrinksafe.py	(working copy)
@@ -29,7 +29,7 @@
     try:
         sourceFilename = sys.argv[1]
     except:
-        print "Usage: %s (<source filename>|-)" % sys.argv[0]
+        print("Usage: %s (<source filename>|-)" % sys.argv[0])
         raise SystemExit
     if sourceFilename == "-":
@@ -51,4 +51,4 @@
 """ % (BOUNDARY_MARKER, sourceFilename, sourceCode))
     ## Deliver the result
-    print urllib2.urlopen(request).read(),
+    print(urllib2.urlopen(request).read(), end=" ")
Index: D:/projects/xebia/vtsPolitie/workspace/openlayers/tools/minimize.py
--- D:/projects/xebia/vtsPolitie/workspace/openlayers/tools/minimize.py	(revision 9165)
+++ D:/projects/xebia/vtsPolitie/workspace/openlayers/tools/minimize.py	(working copy)
@@ -35,7 +35,7 @@
        functions. To add further compression algorithms, simply add
        functions whose names end in _helper which take a string as input
        and return a more compressed string as output."""
-    for key, item in globals().iteritems():
+    for key, item in iter(globals().items()):
         if key.endswith("_helper"):
             func_key = key[:-7]
             if not exclude or not func_key in exclude:
@@ -44,4 +44,4 @@
     import sys
-    print minimize(open(sys.argv[1]).read())
+    print(minimize(open(sys.argv[1]).read()))
Index: D:/projects/xebia/vtsPolitie/workspace/openlayers/tools/oldot.py
--- D:/projects/xebia/vtsPolitie/workspace/openlayers/tools/oldot.py	(revision 9165)
+++ D:/projects/xebia/vtsPolitie/workspace/openlayers/tools/oldot.py	(working copy)
@@ -20,7 +20,7 @@
                 cls = "OpenLayers.%s" % filepath.strip(".js").replace("/", ".")
                 allFiles.append([cls, parents])
     return allFiles
-print """
+print("""
 digraph name {
   fontname = "Helvetica"
   fontsize = 8
@@ -31,13 +31,13 @@
     fontsize = 8
     shape = "plaintext"
 for i in run():
-    print i[0].replace(".", "_")
+    print(i[0].replace(".", "_"))
     for item in i[1]:
         if not item: continue
-        print "%s -> %s" % (i[0].replace(".","_"), item.replace(".", "_"))
-    print "; "
+        print("%s -> %s" % (i[0].replace(".","_"), item.replace(".", "_")))
+    print("; ")
-print """}"""
+print("""}""")
Index: D:/projects/xebia/vtsPolitie/workspace/openlayers/tools/BeautifulSoup.py
--- D:/projects/xebia/vtsPolitie/workspace/openlayers/tools/BeautifulSoup.py	(revision 9165)
+++ D:/projects/xebia/vtsPolitie/workspace/openlayers/tools/BeautifulSoup.py	(working copy)
@@ -422,7 +422,7 @@
         return self._getAttrMap().get(key, default)
     def has_key(self, key):
-        return self._getAttrMap().has_key(key)
+        return key in self._getAttrMap()
     def __getitem__(self, key):
         """tag[key] returns the value of the 'key' attribute for the tag,
@@ -476,7 +476,7 @@
         return apply(self.findAll, args, kwargs)
     def __getattr__(self, tag):
-        #print "Getattr %s.%s" % (self.__class__, tag)
+        #print("Getattr %s.%s" % (self.__class__, tag))
         if len(tag) > 3 and tag.rfind('Tag') == len(tag)-3:
             return self.find(tag[:-3])
         elif tag.find('__') != 0:
@@ -759,7 +759,7 @@
         return found
     def search(self, markup):
-        #print 'looking for %s in %s' % (self, markup)
+        #print('looking for %s in %s' % (self, markup))
         found = None
         # If given a list of items, scan it for a text element that
         # matches.
@@ -785,7 +785,7 @@
         return found
     def _matches(self, markup, matchAgainst):
-        #print "Matching %s against %s" % (markup, matchAgainst)
+        #print("Matching %s against %s" % (markup, matchAgainst))
         result = False
         if matchAgainst == True and type(matchAgainst) == types.BooleanType:
             result = markup != None
@@ -977,7 +977,7 @@
     def __getattr__(self, methodName):
         """This method routes method call requests to either the SGMLParser
         superclass or the Tag superclass, depending on the method name."""
-        #print "__getattr__ called on %s.%s" % (self.__class__, methodName)
+        #print("__getattr__ called on %s.%s" % (self.__class__, methodName))
         if methodName.find('start_') == 0 or methodName.find('end_') == 0 \
                or methodName.find('do_') == 0:
@@ -1012,13 +1012,13 @@
            isinstance(self.currentTag.contents[0], NavigableString):
             self.currentTag.string = self.currentTag.contents[0]
-        #print "Pop", tag.name
+        #print("Pop", tag.name)
         if self.tagStack:
             self.currentTag = self.tagStack[-1]
         return self.currentTag
     def pushTag(self, tag):
-        #print "Push", tag.name
+        #print("Push", tag.name)
         if self.currentTag:
             self.currentTag.append(tag)
         self.tagStack.append(tag)
@@ -1050,7 +1050,7 @@
         instance of the given tag. If inclusivePop is false, pops the tag
         stack up to but *not* including the most recent instqance of
         the given tag."""
-        #print "Popping to %s" % name
+        #print("Popping to %s" % name)
         if name == self.ROOT_TAG_NAME:
             return
@@ -1115,10 +1115,10 @@
             self._popToTag(popTo, inclusive)
     def unknown_starttag(self, name, attrs, selfClosing=0):
-        #print "Start tag %s: %s" % (name, attrs)
+        #print("Start tag %s: %s" % (name, attrs))
         if self.quoteStack:
             #This is not a real tag.
-            #print "<%s> is not real!" % name
+            #print("<%s> is not real!" % name)
             attrs = ''.join(map(lambda(x, y): ' %s="%s"' % (x, y), attrs))
             self.handle_data('<%s%s>' % (name, attrs))
             return
@@ -1139,16 +1139,16 @@
         if selfClosing or self.isSelfClosingTag(name):
             self.popTag()
         if name in self.QUOTE_TAGS:
-            #print "Beginning quote (%s)" % name
+            #print("Beginning quote (%s)" % name)
             self.quoteStack.append(name)
             self.literal = 1
         return tag
     def unknown_endtag(self, name):
-        #print "End tag %s" % name
+        #print("End tag %s" % name)
         if self.quoteStack and self.quoteStack[-1] != name:
             #This is not a real end tag.
-            #print "</%s> is not real!" % name
+            #print("</%s> is not real!" % name)
             self.handle_data('</%s>' % name)
             return
         self.endData()
@@ -1582,15 +1582,15 @@
                       markup)
         try:
-            # print "Trying to convert document to %s" % proposed
+            # print("Trying to convert document to %s" % proposed)
             u = self._toUnicode(markup, proposed)
             self.markup = u
             self.originalEncoding = proposed
         except Exception, e:
-            # print "That didn't work!"
-            # print e
+            # print("That didn't work!")
+            # print(e)
             return None
-        #print "Correct encoding: %s" % proposed
+        #print("Correct encoding: %s" % proposed)
         return self.markup
     def _toUnicode(self, data, encoding):
@@ -1764,4 +1764,4 @@
 if __name__ == '__main__':
     import sys
     soup = BeautifulSoup(sys.stdin.read())
-    print soup.prettify()
+    print(soup.prettify())
More information about the Dev mailing list
