[OpenLayers-Dev] WFS And Zoom Levels
    Andrew Ayre
    andy at britishideas.com
    Sun Apr  5 15:27:47 EDT 2009
Solved. I needed to set the projection on the WFS layer to match the
projection used for the layer data in Mapserver. I guess it is handled
automatically when using the built in WFS feature class, but not when
you override it.
Andy
Andrew Ayre wrote:
> I see that if I set:
>   featureClass: OpenLayers.Feature.WFS
> then the WFS data is shown at all zoom levels. So it doesn't work when I
> use my own feature class. Is there something extra I need to do here to
> make it work? The initialize function in my feature class isn't called
> even though the GML is fetched.
> thanks, Andy
> Andrew Ayre wrote:
>> Hi! I have a WFS layer that only shows at the 10 smallest zoom levels.
>> If I switch to the 11th zoom level (zooming in) the GML file is
>> fetched but the markers are not added.
>> I have tried setting the maxResolution, minResolution, etc. parameters
>> for the layer to match the map, but with no luck. Can anyone please
>> give me some hints?
>> Thanks!
>> map = new OpenLayers.Map ("map", {
>>   controls:[
>>     new OpenLayers.Control.Navigation(),
>>     new OpenLayers.Control.PanZoomBar(),
>>     new OpenLayers.Control.Attribution(),
>>     new OpenLayers.Control.LayerSwitcher()],
>>   maxExtent: new
>> OpenLayers.Bounds(-20037508.34,-20037508.34,20037508.34,20037508.34),
>>   maxResolution: 156543.0399,
>>   numZoomLevels: 19,
>>   units: 'm',
>>   projection: new OpenLayers.Projection("EPSG:900913"),
>>   displayProjection: new OpenLayers.Projection("EPSG:4326")
>> var czwfs = new OpenLayers.Layer.WFS("Test Data",
>> "/mapserverredirect/cgi-bin/mapserv.cgi"
>>     typename: "TESTPOINTS2", maxfeatures: 300, map: '../wms.map'
>>     featureClass: CacheZone.Feature.Points,
>>     maxResolution: map.maxResolution,
>>     minResolution: map.minResolution,
>>     numZoomLevels: map.numZoomLevels,
>>     units: map.units,
>>     scales: map.scales,
>>     resolutions: map.resolutions,
>>     minZoomLevel: map.minZoomLevel,
>>     maxZoomLevel: map.maxZoomLevel
>> Andy
Andy
PGP Key ID: 0xDC1B5864
More information about the Dev
